-   Polish/Cleaners/Compounds/Glaze (http://www.detailingworld.co.uk/forum/forumdisplay.php?f=12)
-   -   Sonus Paintwork Cleanser......... (http://www.detailingworld.co.uk/forum/showthread.php?t=26058)
John-R- 23-03-2007 09:20 PM
Is this any good? got it with my autopia order as a freebee, when should I apply it? I'm thinking after I use the 106FF and before the Wax? is this correct?
John
http://i167.photobucket.com/albums/u...-/CIMG0043.jpg
Phil H 24-03-2007 10:07 AM
i like using it, nice smell, easy to apply and remove. do a panel at a time in straight lines leave a for a few mins then wipe off. Use it just before you apply a wax of your choice.
TriBorG 24-03-2007 12:11 PM
When using the Paintwork Cleanser Would you normally do this by hand or PC ?
John-R- 24-03-2007 05:26 PM
Cheers Phil :thumb:
John
Rayman 24-03-2007 09:56 PM
PC normally!:buffer: by hand would be fine too on an applicator pad!
typefern 25-03-2007 10:10 PM
Is this safe to use after you have carried out swirl correction? I think it has a abrasive compound in it, which would result iin adding swirls.:confused:
Cheers John
typefern 26-03-2007 09:41 PM
Any thoughts please
John
mba 26-03-2007 09:44 PM
The Sonus paint cleaner is a chemical cleaner and to my knowledge contains no abrasives at all.
Some people are of the thought that if you are PC'ing a car then there is no need for paint cleaner - although im starting to think i should go back to using it!
typefern 26-03-2007 09:48 PM
Cheers MBa
A lot of people seem to be using the Zymol HD Cleanser, just wondering if you can use it the same way.
John
bpsmith 27-03-2007 08:36 AM
I am not 100% on this either and thought I should be using the Cleaner after the Polish and prior to the Glaze, which is then followed by the Sealant.
Or is this overkill?
