-   Bear Car Care (http://www.detailingworld.co.uk/forum/forumdisplay.php?f=423)
-   -   Bear car care - eradicate fall out remover product review (http://www.detailingworld.co.uk/forum/showthread.php?t=409132)
Bustanut 14-10-2018 09:01 AM
My parcel arrived on Friday morning, thanks Ash.
http://i.imgur.com/YrVQGrv.jpg
It arrived in perfect time for a pre sale clean up.
First review is of Bears Eradicate fallout remover. My first impression was the bottle and trigger feel nice and robust and it sits nicely in the hand (500ml bottle tested). It was nice to see a full size trigger as I cannot stand the tiny ones that some other suppliers use at present.
http://i.imgur.com/9KHU9cW.jpg
The smell is to be expected and is similar to other fall out removers.
The wheels were filthy as they had not been cleaned in a while so I sprayed a good amount onto a dry wheel and let it sit for a few
http://i.imgur.com/QXZttH1.jpg
First impressions were good as it looked like a more gel and stayed in place on the wheel without running down.
http://i.imgur.com/1qTcfEg.jpg
http://i.imgur.com/MDp6BKj.jpg
As the wheels were so dirty I decided not to agitate and just pressure washed off to give an idea of cleaning power.
It rinsed off easily and took most of the dirt with it.
http://i.imgur.com/MlL4YH5.jpg
They did need another hit so I sprayed them again and let it sit for a minute before agitating with various wheel brushes. The product gave a light foam as it was agitated and seemed to pull the last bits of dirt off with out any problem.
Would I use it again. Yes I like the bottle and the trigger is a big plus as is the viscocity of the product.
Andyblue 14-10-2018 09:28 AM
Good review - nice package of ďsamplesĒ to try out sent to you. Very generous to send full size samples out :thumb:
Looks to have cleaned wheels well - Iíve used their Vortex wheel cleaner (gel type as well) and have been very pleased with it, so I think adding this as a 2nd stage cleaner would be brilliant.
Liking the fact this is a gel type, so doesnít just run away from what itís supposed to do...
Looking forward to your thoughts on the other samples you got to try :thumb:
nbray67 14-10-2018 09:36 AM
Hi Bustanut.
While in IMGUR, open up the image, select 'large thumbnail' in the image sizes, click on the 'copy' button on the BBCode and simply paste this link onto the forum as per this -
I see your links above don't have [img] and [/img] at the beginning/end of the links.
Hope this helps pal.
https://i.imgur.com/bgPbcNxl.png
Bear_Ash 14-10-2018 10:47 AM
Originally Posted by Bustanut (Post 5504922)
My parcel arrived on Frida morning, thanks Ash.
https://i.imgur.com/YrVQGrv.jpg
https://i.imgur.com/9KHU9cW.jpg
The wheels were filthy as they had not been cleaned in a while so I sprayed a good amount onto a dry wheel and let it sit for a few minutes.
https://i.imgur.com/QXZttH1.jpg
https://i.imgur.com/1qTcfEg.jpg
https://i.imgur.com/MDp6BKj.jpg
https://i.imgur.com/MFEkLFt.jpg
Apologies for links to photos I couldnít get the pics to post from imgur.
Morning Buddy,
Thank you for this I am pleased you like the triggers as this is a recent change.
I was fairly happy with the first triggers I choose but after some feedback and another look they just didn't do the iron remover or wheel cleaner justice.
So after resting I decided to change the whole range and upgrade to the triggers you received. With these they handle product a lot better and you can go from a ultra fine mist for a detailer to a stronger jet for a wheel cleaner or pre wash.
for me its all part of making sure the product and packaging work as well as they can and with these new triggers I belive its now 100%
Bustanut 14-10-2018 12:22 PM
Thanks, I much prefer the gel type fall outs and Iíve tried most of the big brands. Other reviews to follow once I can figure these photos out.
Bustanut 14-10-2018 12:24 PM
Originally Posted by nbray67 (Post 5504929)
Hi Bustanut.
Thanks for your help. I have the photos up as per your instructions but they are really big.
Bustanut 14-10-2018 12:26 PM
Originally Posted by Bear_Ash (Post 5504941)
Morning Buddy,
Ash, I love these triggers. One of the best I’ve used. Ergonomically spot on. Be keen to see how they last over time, especially with product like fallout removers through them.
nbray67 14-10-2018 02:05 PM
Did you click on the image size - large thumbnail?
If so, try small or med thumbnail although that image I posted up is a large thumbnail.
You can preview the post before you post it up if that helps pal.
Bustanut 14-10-2018 02:45 PM
I used my iPad and the screen looked nothing like the option you showed. Iíll figure it out eventually.
Thanks again
