Machine Polishing Sponsored by www.Shinearama.co.uk
Old 22-04-2012, 04:26 PM   #1
blader1611
Polished but not quite enough
Just had my first go with the das6 pro and menzerna polish with flexipads. i did a test panel on the bonnet with the 3000 polish (final finish) and the firm polish pad. this worked a treat so did the whole bonnet but it has left one or 2 what i can only assume is deeper swirls. Would it be best to do another round with the same combo or go for a same polish but a cutting pad or polish pad with more aggresive polish?
blader1611 is offline   Reply With Quote
Old 22-04-2012, 07:17 PM   #2
PaulN
PaulN's Avatar
I'd hit it again with the lighter combo before stepping up now. Test again on another panel after this if you want to try a heavier cut combo.
What grade is the pad sounds like a polishing pad not finishing.
PaulN is offline   Reply With Quote
The Following User Says Thank You to PaulN For This Useful Post:
blader1611 (22-04-2012)
Old 22-04-2012, 08:13 PM   #3
blader1611
I was using the yellow polishing flexipad with Menzerna FF. It did a great job on the test panel but in other areas it left one or two deeper swirls in there. I was pretty pleased with the results but would have liked to have corrected it fully. I will try another hit on it next weekend, its Ford paint so may be slighter harder than I thought.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
