Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bilt Hamber
Old 18-01-2018, 05:49 PM   #81
Commander2874
Originally Posted by Ch!lledBudwei2er View Post
Thought I should add my thoughts after picking up a new foam for easy washing.
With two kids under 2yo and a works injury leaving me with a bulging disc in my back, I'm not likely to be able to do much car washing for a while! I've tried a couple different snow foams, last being some left over ValetPro Advanced Neutral Snow Foam, always left with a feeling of it being a half decent pre-wash, but nothing more than that.
I highly rate the Bilt Hamber shampoo so with some positive reviews I bought 5l of the auto-foam.
I had a very dirty Mazda5 that has been caked in mud for a couple of weeks. Followed the dilution rate from the OP, and ended up with just over 50% of foam to water. Used about 300ml of the 1l with about 1.5 passes of the car.
Car was wet as it was beginning to rain heavily.
WOW
I had no real expectation of it working as well as it did, in fact it worked so well, I won't be getting my two buckets out for a mitt wash for a long while!
BH do great products. Literally spent about 5 -8 mins cleaning my engine plastic skirt with Surfex HD, which had never been cleaned. Came out looking 100% better!
Sent from my SM-N910F using Tapatalk
Commander2874 is offline   Reply With Quote
The Following User Says Thank You to Commander2874 For This Useful Post:
Brian1612 (18-01-2018)
Old 18-01-2018, 08:40 PM   #82
pxr5
pxr5's Avatar
Excellent review Brian. That's probably one of the most clear, useful and informative reviews I've seen. Thank you.
The Following User Says Thank You to pxr5 For This Useful Post:
Old 01-02-2018, 07:08 PM   #83
gaznrx8
gaznrx8's Avatar
Originally Posted by Brian1612 View Post
As max said I haven't had any issues leaving the mix in the bottle until the next wash.
Hi
I’ve just calculated how much I need to get 4% pir and it’s 600ml of BH Autofoam. I did the calculations using the same method you described but seems a lot to me ?
Mines a snow foam lance 1L. I’ve used for a few years bought from one of the forum sponsor shops on here. Also using a Nilfisk c120 PW.
Gary
gaznrx8 is offline   Reply With Quote
Old 01-02-2018, 07:32 PM   #84
Hereisphilly
Dw Reviewer
Hereisphilly's Avatar
Originally Posted by gaznrx8 View Post
Hi
Gary
Sounds about right that
Sent from my Pixel 2 XL using Tapatalk
Old 01-02-2018, 08:16 PM   #85
gaznrx8
gaznrx8's Avatar
Seams a lot of product to use then gonna cost me a fortune lol.
Gary
Old 01-02-2018, 08:19 PM   #86
Hereisphilly
Dw Reviewer
Gary
Don't forget you hardly need any of this product Vs traditional snowfoams
Just enough to wet the car and work with short sharp bursts of the lance
I get 4 applications per 1l lance bottle which works out fine for me, but if you want to use less you can use it in a pump sprayer
Old 01-02-2018, 08:32 PM   #87
gaznrx8
gaznrx8's Avatar
Not sure if I’m aloud to name car detailing suppliers on here but the BH Autofoam supplied by them gives you instructions to use 50:1 water/product 200ml of Autofoam then fill the litre bottle to the top ?
Old 01-02-2018, 09:26 PM   #88
gaznrx8
gaznrx8's Avatar
It also states on the front of the BH auto foam container feed ratio upto 1:100
Old 01-02-2018, 10:05 PM   #89
Hi
Gary
With my new set up I actually use 550ml to 450ml water in the bottle so your amount seems fairly accurate. What you need to remember is you don't need to use up the full bottle. Anything more than a thin coat of foam is a waste of product. Your simply wetting the car with foam and no more than that. 1 pass of each panel in a quick side ways movement on a fairly wide spread is all you need.
A 1ltr mix should coat 5 cars at least so in reality your only using 120ml per wash. I also replied back to your PM bud
Old 01-02-2018, 10:09 PM   #90
gaznrx8
gaznrx8's Avatar
Thanks for your reply
I tried to use the same method as you did in your video and out of the 1L bottle I’ve got half left and that’s with a 1 series Bmw lol so I’ll try and work on a better technique.
Or I could try turning down the lance knob to slow down the output of the snowfoam ?
bilt hamber auto foam, prewash, snow foam, touchless car wash
