Old 23-06-2017, 12:15 AM   #11
nick_mcuk
nick_mcuk's Avatar
Send a message via MSN to nick_mcuk
Originally Posted by c87reed View Post
As discussed above, I used 2500, then 2000, then 1500 wet and dry with a soap solution. Used an old fine Rupes pad on the DA and fine polish to clear sanding marks and polish up. Headlight is past its best but was good enough for MOT. Once cleaned off with Eraser I topped it off with DLUX.
So you went from a fine grade paper to a coarse grain paper to finish up???
Different method!
nick_mcuk is offline   Reply With Quote
Old 23-06-2017, 12:17 AM   #12
c87reed
c87reed's Avatar
Different method!
No ha ha, I meant to write 1500, 2000, then 2500.
c87reed is offline   Reply With Quote
Old 23-06-2017, 12:46 AM   #13
Titanium Htail
Titanium Htail's Avatar
I did 1500 2000 2500 all wet, Mike@Autogeek suggests keep all papers in individual wet containers, used the 1500 untill the slurry was clearer, then 2000 2500 after. Followed up with #105 LC Orange...all good here on this Clio.
Titanium Htail is offline   Reply With Quote
Old 29-06-2017, 03:47 PM   #14
robwils
robwils's Avatar
Did my daughters car over weekend, tried using the meguirs kit that I bought but wasn't harsh enough to remove yellow colour on headlight.
Wet sanded starting with 600 then moved finer, eventually finished of with megs 205/105 on my mini shinemate unit, green and orange pads.
Well pleased as it was my first go at this sort of thing and MOT passed
pic after 1 light for comparison.
robwils is offline   Reply With Quote
The Following User Says Thank You to robwils For This Useful Post:
percymon (28-02-2018)
Old 29-06-2017, 04:10 PM   #15
GP Punto
GP Punto's Avatar
Good information, learned a lot. Last pair of lights I did I went about it in a different way but only because I already had the materials in for some other work.
Started with metal polish, I had some Simichrome - use other metal polish now such as Solvol. Then went to 2500 then 4000 micromesh and then Plastrx.
Results were perfect at that point but it was suggested that I use a wax protection and used Renaissance wax which is a brand of microcrystalline wax polish in antique restoration and museum conservation. Someone else said that I would have got just as good a protection with a domestic spray polish for furniture that has a high wax content, meant for wood furniture, not Mr Sheene or Pledge, nowhere near enough wax content.
GP Punto is offline   Reply With Quote
Old 04-01-2018, 05:27 PM   #16
olliewills
Is this any help to you?
https://youtu.be/uqOKmZ9mMfc
Sent from my One using Tapatalk
Old 21-02-2018, 08:45 PM   #17
Itstony
Itstony's Avatar
Ditto, has to be 1500-2000-2500 and manually is easiest if first time.
Plastic X gets a big thumbs down from me, so that's been answered.
Patience on the wet sanding is probably key to be sure no heavier scratches are left. They wont polish out as easy if left.
The polishing off with a medium cut on polycarbonate is my choice and having an iBrid makes it quite easy.
Using a 100mm DA not for me, tried once and wouldn't use it again.
All personal choice I guess.
Seal with Chem Guys Jet Seal is a personal favourite product of mine, so versatile. Not cheap but goes a long way.
Wax works good, just need to wipe them over regular with more which makes sure they are protected, hardly an effort on such small areas.
PS.
Watched that link given above, had I have watched that I would not have had to learn the hard way. That YouTube is excellent short cut without trial and error.
Old 21-02-2018, 09:01 PM   #18
slim_boy_fat
slim_boy_fat's Avatar
"Using a 100mm DA not for me"
I finished mine off with a 2" wool pad in the DA - did the job spot on
Old 27-02-2018, 10:47 PM   #19
Harry_p
I cleaned up a merc headlight recently. Was going to buy one of the kits but decided to just use the kit I had at home.
A 1/4 sheet of p2500 folded a few times, used wet, then a hand polish with red bottle t-cut ( yes really ) and a coat of wax.
Harry_p is offline   Reply With Quote
The Following 2 Users Say Thank You to Harry_p For This Useful Post:
B8sy (27-02-2018), slim_boy_fat (28-02-2018)
Old 28-02-2018, 10:52 AM   #20
slim_boy_fat
One of the most satisfying jobs you can do in terms of 'visible' [see what I did there? ] results.
