Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > in2Detailing
in2Detailing www.in2detailing.co.uk
| 01382 622565 | Price Match Promise TAC Systems - Bilt Hamber - Chemical Guys - Bouncers - Prima Car Care - Krystal Kleen Detail - Wheel Woolies - ViseeO Authorised Distributor
Old 29-07-2017, 07:00 PM   #21
waqasr
waqasr's Avatar
Imran, Refinish Ultra says it removes 600 grit scratches and polishes at 12k grit. Would this be good on a hard pad for hard german paint? Also how does it compare and differ from Tac all in one nano compound?
Thanks.
waqasr is offline   Reply With Quote
Old 29-07-2017, 07:47 PM   #22
In2detailing
DW Sponsor
In2detailing's Avatar
Thanks.
Refinish Ultra is suitable for all paint types, just adjust pad accordingly.
All in one and Refinish ultra finish about the same, if you want to be critical all in one will finish a bit better, however the cut is higher on refinish ultra because it uses newer diminishing abrasive tech.
Hope that makes sense
Imran
Discount Code DW10
In2detailing is offline   Reply With Quote
The Following User Says Thank You to In2detailing For This Useful Post:
waqasr (30-07-2017)
Old 30-07-2017, 02:28 AM   #23
waqasr
waqasr's Avatar
Perfect sense, will go with the ultra I think!
Old 09-08-2017, 05:31 PM   #24
kevincwelch
I just ordered some Aqua Waterless Wash. I looks like this can be used directly out of the bottle without diluting. Can it be diluted to use in a RINSELESS wash?
kevincwelch is offline   Reply With Quote
Old 09-08-2017, 09:42 PM   #25
In2detailing
DW Sponsor
You would use this as a Waterless wash, not a rinse less wash.
You probably could dilute it a bit but it was not designed to be diluted.
Can be used as a quick detailer aswell.
Different to quartz max as aqua Waterless has cleaning ability so can be used on a lightly dusty car whereas quartz max is more a spray sealant.
Might not be for everyone but I have used it, good gloss and protection as you would expect for a sio2 based product. As with any Waterless wash, multiple cloths is essential. Spray on the panel, spray a bit on the cloth and take one swipe to remove the dust. Do not use that side again, flip for another swipe and so on until that panel is complete and then just give it a final buff. It works, and works well for its intended purpose. The method and safety will of course be a matter is debate but as I said, you can use it as a quick detailer no problem.
Hope that helps and makes sense
Imran
Discount Code DW10
Old 10-08-2017, 05:29 AM   #26
kevincwelch
It does, and that's what I was assuming. I was just curious if anyone has used it off-label as a rinseless wash as well.
Old 10-08-2017, 10:13 AM   #27
Yellow Dave
Yellow Dave's Avatar
Can't even find that product on the i2d website?
Old 10-08-2017, 01:26 PM   #28
kevincwelch
It's on the TAC System USA website.
Old 10-08-2017, 01:35 PM   #29
litcan91
I'm having troubles with Water Spot Zero, using it on windows which had water spots from hard water, wipe on leave to dwell (less than minute usually, it dries instantly) and it becomes a nightmare to wipe off - so much so that it has added its own streaks which seem to be impossible to remove without machine polishing.
Am I doing something wrong here?
litcan91 is offline   Reply With Quote
Old 10-08-2017, 03:01 PM   #30
kevincwelch
For water spot zero, I usually spray just shy of generously and wipe off very quickly. I haven't experienced any drying or streaking. It has affected the hydrophobic properties of some of the coatings, but I haven't seen any streaking.
Is your paint cool to touch? Out of the sun?
