Old 26-01-2017, 09:04 PM   #1
buffdaddy
Wet sanding pneumatic vs electric
Hi all
Looking to remove some orange peel. Looking at many videos out there everyone uses Air sanders.
Are there any issues sanding using electric DA such as a DAS6? I can't see why there would be??
buffdaddy is offline   Reply With Quote
Old 26-01-2017, 10:27 PM   #2
Uncle Winnet
electricity and water mmm what could go wrong
Uncle Winnet is offline   Reply With Quote
The Following User Says Thank You to Uncle Winnet For This Useful Post:
AllenF (26-01-2017)
Old 26-01-2017, 10:47 PM   #3
Shogun
What could go wrong ?
https://www.amazon.com/Flex-LW1503-C.../dp/B002OHEB3E
Shogun is offline   Reply With Quote
Old 26-01-2017, 10:47 PM   #4
AllenF
The reason I don't use a kettle...
Air because you can "stall" it easier than electric hence you only let the air da supply the pressure not add some by leaning on it. This you don't cut too much in one pass but you do cut evenly.
Plus the air da's I have used are faster opm than electric "about 10000 rpm which is a lot lower than the actual opm { revs per minute and orbits per minute 10000 rpm could be in the region of 40000 opm})
Plus only a complete dick would sand with the same machine he polishes with (dust and fine grit and a finish glaze mmmmmmm nicccccce)
AllenF is offline   Reply With Quote
Old 26-01-2017, 11:40 PM   #5
buffdaddy
What are you talking about mate, you're not dipping the machine in a bucket of water, just a spritz on the panel
The Following User Says Thank You to buffdaddy For This Useful Post:
RandomlySet (27-01-2017)
Old 27-01-2017, 01:12 AM   #6
buffdaddy
Why would rupes bring out the duetto then? Must be complete dicks the lot of them
Old 27-01-2017, 10:38 AM   #7
Dave170
Dave170's Avatar
There are no problems using a DA for sanding, but its more about common sense when it comes to the amount of water you use spritz don't soak. Make sure you don't put pressure on the machine just use the weight of the DA, and inspect the panel after each pass and clean the sanding disc regular to avoid pigtails.
Personally for me I prefer to wet sanding by hand, I know its slow but I get a better feel for how the paint is behaving.
You might find this link useful http://www.meguiarsonline.com/forums...iUyUWASQlII.97
If you are planning on doing your car, make sure you practice on some scrap panels and are happy with the results you are achieving before giving it a go on car as things can go wrong pretty fast especially with a machine.
You might want to also think about a paint thickness guage see if you can hire, borrow or buy one this will allow you to know how much you have to play with and how much you are removing.
Dave170 is offline   Reply With Quote
Old 27-01-2017, 10:44 AM   #8
stangalang
king of the flexonian
stangalang's Avatar
Its less to do with "air vs electric" and more to do with throw and opm. There are electric units out there specifically for refinishing paint and there are air units that will destroy paint.
My advice, the smaller the throw the better, and something that doesn't have a massive counter weight
Old 27-01-2017, 10:48 AM   #9
AllenF
Da's are all derived from Sanders. Rotarys are derived from grinders. The all polished are "capable" of sending but would you use the same machine to do both tasks.
Sending whether wet or dry will spatter done that and abrasive into the working of the machine. Polishing will do the same but the two substances are different
The Following User Says Thank You to AllenF For This Useful Post:
Old 27-01-2017, 10:49 AM   #10
Alan W
Alan W's Avatar
Festool Rotex is good.
Alan W
stangalang (27-01-2017)
