Old 29-04-2018, 05:22 PM   #351
restricted
Originally Posted by jbenekeorr View Post
I donít know if I would use the word ďSkillsĒ Iíd be happy to impart any wisdom I can.
From your thread it sounds like you just need to have a go and see how you get on. Personally Iíve only ever used a DA - as itís very difficult to do any damage with one, which works for me Iíve had good results on a few VW group cars (one of which was a Bentley!)
Thank you for the offer...
oh I always have a go, my RS6 and S2 I got great results on and I painted my motorbike and then flatted it all back and then machine polished it, that I am very happy with.
It's just my bloody cars I get so frustrated with...... I blame my age hahaha
restricted is offline   Reply With Quote
Old 29-04-2018, 08:59 PM   #352
Brooklands
Brooklands's Avatar
Just spent the last hour working through the entire thread and WOW - what a story!
Most excellent work!
Brooklands is offline   Reply With Quote
The Following User Says Thank You to Brooklands For This Useful Post:
jbenekeorr (29-04-2018)
Old 29-04-2018, 09:03 PM   #353
The_Weasel
The_Weasel's Avatar
I don’t think that’s the cause in this instance, as when I changed the supercharger pulley, I fitted a new Gates belt and confirmed the length of it was correct for that pulley with 1320 Mini.
I figured that the tensioner and the other idler wheel (if that’s what it’s called) must be relatively worn by now, so I should probably replace them regardless.
Edit - meant to ask, what are your thoughts on that? As I’d appreciate a second opinion before I take it to bits. I have sort of ruled out the belt itself for the above reasons. I was thinking of having the alternator refurbed as a matter of course - whilst it’s out.
The only way to get the hole to show is to fit a shorter belt than the one that is on, so that it contracts the tensioner more.
All the tensioners are identical.
What size pulley have you got and what size belt?
The_Weasel is offline   Reply With Quote
Old 29-04-2018, 09:05 PM   #354
jbenekeorr
jbenekeorr's Avatar
Itís a 11% pulley and 1375mm Gates belt. What do you reckon?
Old 29-04-2018, 09:21 PM   #355
The_Weasel
The_Weasel's Avatar
Sounds the correct size, but strange you've no hole showing
Old 29-04-2018, 09:24 PM   #356
jbenekeorr
jbenekeorr's Avatar
I was rather hoping youíd tell me I had the wrong belt and everything would be sorted
I could get another belt to be sure it hasnít stretched I suppose.
Old 29-04-2018, 09:24 PM   #357
Some more cracking write ups and updates
Old 29-04-2018, 09:31 PM   #358
The_Weasel
The_Weasel's Avatar
If you swap the tensioner and the idler pulleys are all ok and you still don't have a hole showing, then just get a shorter belt.
The damper can fail on the tensioner but it doesn't usually affect the actual tension and amount of holes showing. It will be interesting to find out what you discover
Old 29-04-2018, 09:36 PM   #359
jbenekeorr
jbenekeorr's Avatar
Ok, thanks for your advice. Iíll investigate it and let you know the findings!
Old 29-04-2018, 09:50 PM   #360
The_Weasel
The_Weasel's Avatar
Should have said, the easiest way to change it is OSF wheel off and remove arch liner, oh look, your favourite clips
Easiest way with them clips is press a screwdriver against the outside part to stop it spinning and then unscrew the middle, then pull them out, they really are easy
