Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bilt Hamber
Bilt Hamber Bilt-Hamber Laboratories has always used research, innovative chemistry and thorough testing as the way to produce better performing products. Every product released for sale has been extensively compared to and tested for superiority against market leading and specialist competitive formulations. From our clay bars to cavity waxes, etch primers to carnauba waxes and shampoos to rust removers, each Bilt-Hamber formulation has been made from conception to production with the same care.
Old 22-11-2017, 04:09 PM   #51
sm81
About 5 year shelf life
The Following User Says Thank You to sm81 For This Useful Post:
Brian1612 (25-11-2017)
Old 22-11-2017, 07:27 PM   #52
MaDMaXX
MaDMaXX's Avatar
Yeah, it's not something you would worry about, i know i'm sharing my 5 gallon with my Brother, but we'll be through it in a couple if years at most.
MaDMaXX is offline   Reply With Quote
The Following User Says Thank You to MaDMaXX For This Useful Post:
Old 25-11-2017, 02:32 PM   #53
Yellow Dave
Yellow Dave's Avatar
Based on the dilution it's hitting the panel, did you run the same dilution when using you're preferred snow foam?
Maybe I'll be generic method of an inch in the bottom of the bottle is far to diluted as well
The Following User Says Thank You to Yellow Dave For This Useful Post:
Old 25-11-2017, 04:15 PM   #54
Brian1612
Brian1612's Avatar
Yellow Dave I didn't use the BH directions for the other foams as it's not how they instruct you to use it. I thought the most fair way to do the test is to use it as directed by each company plus I suspect if I used 510ml in the lance of the other brands foam it would come out like shaving foam.
The Following 2 Users Say Thank You to Brian1612 For This Useful Post:
MaDMaXX (26-11-2017), Yellow Dave (25-11-2017)
Old 30-11-2017, 04:30 PM   #55
Robbi Hong Kong
Robbi Hong Kong's Avatar
I have a Kranzle K10...I always use BH Autofoam.....560ml water to 440ml of product gives me the 4% PIR.....
Robbi Hong Kong is offline   Reply With Quote
The Following User Says Thank You to Robbi Hong Kong For This Useful Post:
Brian1612 (30-11-2017)
Old 30-11-2017, 04:53 PM   #56
benjcarter
Your review alone has converted me Cant wait to try it. Thanks for the great review.
benjcarter is offline   Reply With Quote
The Following User Says Thank You to benjcarter For This Useful Post:
Old 30-11-2017, 07:00 PM   #57
DLGWRX02
DLGWRX02's Avatar
I’ve been using it now this last couple of weeks through my valet pro foam blaster adding 400mls to 8 litres of water, this is enough to do my car twice, and it makes so much more of a difference compared to how I used to just put an inch in the bottom of a foam lance. As a comparison I used it at the weekend putting approx 450ml in my foam lance bottle and using it via my k5 pw, yes it was much quicker this way and it covered the car in more of a thicker foam. The difference being after giving the car a complete layer covering, there was just enough left to give the wife’s Aygo a thin covering. Cleaning was just as good aswell, getting rid of most the road grime it had collected over the last 500 miles since previous wash.
Edit:
After watching the video in the first post, that is how I done the wife’s Aygo, and was ample. I recon if I was to do my RRS that way it would use much less! It’s getting out the habit of wanting to see thick covering of foam clinging all over the car.
The Following User Says Thank You to DLGWRX02 For This Useful Post:
Old 06-12-2017, 09:35 AM   #58
Brian1612
Brian1612's Avatar
Edit:
That is exactly it DLG
When I first questioned the economy of auto-foam, that was the problem I had to deal with. I spoke to Pete at BH and he told me you only need to 'wet' the car with auto-foam for it to work. His explanation was it's only a very thin layer touching the paintwork, if you fire lots on, it is still only the thin layer touching the paint, the rest of the foam applied is doing nothing and just waste of product.
A single pass with the lance set to a reasonably wide spread is all that is required
bigkahunaburger (14-12-2017), MaDMaXX (06-12-2017)
Old 06-12-2017, 11:08 PM   #59
markcaughey
Nice review Brian ! I have just run out of Koch Chemie green star but think I'm going to pick up a 5L of this.
Think as you say running it through pump sprayer is the way to go thats what I have been doing with the green star but I find you need quite a strong dilution with green star for it to be effective so looking forward to trying out the Auto Foam !
markcaughey is offline   Reply With Quote
The Following User Says Thank You to markcaughey For This Useful Post:
Brian1612 (07-12-2017)
Old 06-12-2017, 11:25 PM   #60
Blueberry
Blueberry's Avatar
What dilution do you use Green Star at? I use it 1:20 and it cleans better than foam would, even on a very dirty car. For me GS is the best.
The Following 2 Users Say Thank You to Blueberry For This Useful Post:
Brian1612 (08-01-2018), sean ryan (09-12-2017)
bilt hamber auto foam, prewash, snow foam, touchless car wash
