Old 06-12-2016, 08:17 PM   #1
Ian 1971
Ian 1971's Avatar
Dusting
Using megs 105 and 205 on my Neyara Blue Seat Aleta. Have used white and orange hex logic pads but am getting whit dust. Is this my technique or working time. Definitely not using too much polish(am only using a couple of pea sized drops as per junkman)
Ian 1971 is offline   Reply With Quote
Old 06-12-2016, 08:25 PM   #2
AutoCleanEurope
AutoCleanEurope's Avatar
Hi buddy, are your pads dry to start? Normally best to wet them a little first and durning with a spray of water.
AutoCleanEurope is offline   Reply With Quote
Old 06-12-2016, 08:25 PM   #3
AutoCleanEurope
*during not durning!!
Old 06-12-2016, 08:27 PM   #4
Ian 1971
Ian 1971's Avatar
Hey, thanks for getting in touch, never tried that to be fair. Will give it a shot, wondered if it may be down to cooler weather? I'm pretty new to using my DA
Old 06-12-2016, 08:40 PM   #5
scratcher
scratcher's Avatar
There could be a few factors in it.
Too much product, working too large an area, not cleaning the pads out enough.
Like to give a very light spritz of water over the pad when using 105 and 205. You don't need to soak it. Just a light dusting - as above - and then pop your polish on the pad.
scratcher is offline   Reply With Quote
Old 06-12-2016, 10:27 PM   #6
diggy87
I've heard that megs 105 and 205 are quite dusty products anyway?
diggy87 is offline   Reply With Quote
Old 08-12-2016, 12:46 AM   #7
Paul7189
Paul7189's Avatar
105 is dusty. 205 is really nice to use and can be worked for ages.
Paul7189 is offline   Reply With Quote
The Following User Says Thank You to Paul7189 For This Useful Post:
Ian 1971 (30-01-2017)
Old 08-12-2016, 08:47 AM   #8
105 is a very dusty compound if you use a foam pad but is less dusty if you use a MF pad and a spritz of water as the compound starts to break down, but as for 205 it's a great polish for refinement after 105. How long are you working 105? And what speed are you using.
Old 08-06-2017, 02:32 PM   #9
litcan91
What would you guys recommend that is less dusty but as effective as the 105 205 combo? Dust is the main thing putting me off as there it almost requires for the whole car to be covered (way too much prep).
I've been using QD to moisten the pads, working at speeds of 4-5.
litcan91 is offline   Reply With Quote
Old 08-06-2017, 03:58 PM   #10
Surrey Sam
Try slow everything down - arm movements, machine speed and clean the pads more frequently.
If you're still not happy or getting any improvement, then give some Koch Chemie H8 ago instead.
Surrey Sam is offline   Reply With Quote
