Old 04-01-2017, 01:27 PM   #1
MysteryMan
Recommend cloth for cleaning interior windscreen
I am having problems cleaning the inside of windscreen.
Just used Nilglass spray, spread with a Paragon Fish-Scale MF cloth and then wiped with short-pile MF cloth.
The glass looks really clean, but, when the sunlight catches the windscreen then you can see what look like tiny hairs/bits on the glass.
I am guessing that these are from the MF cloth I used to buff with.
Can somebody suggest what cloth I should be using to avoid this happening, please?
MysteryMan is offline   Reply With Quote
Old 04-01-2017, 02:11 PM   #2
Buff with another fishscale cloth, even then I find I get the little hairs, it's extremely annoying when the glass is clean apart from the tiny little bits of pile. I'm going to try one of my Polished Bliss utility towels to see if the closed loops help....
firehorse (05-01-2017)
Old 04-01-2017, 02:14 PM   #3
MysteryMan
OK, thanks....please post a reply when you've tried the closed loop MF!
Old 04-01-2017, 03:27 PM   #4
neilmcl
I bought a pack of these Paragon cloths and I'm not too impressed, sure they OK to clean with but they are very grabby, impossible to buff with. Personally I prefer a waffle weave cloth.
Unless you've done so I'd recommend washing your MF cloths before first use, this should minimise any fluff coming off them.
The Following User Says Thank You to neilmcl For This Useful Post:
Old 04-01-2017, 03:50 PM   #5
shine247
shine247's Avatar
E-cloth for glass, no bits and easy to use. I noticed the same problem as you in sunlight, the E-Cloth put an end to it in one go, no re buffing.
The Following 4 Users Say Thank You to shine247 For This Useful Post:
firehorse (05-01-2017), Ross (04-01-2017), Sid (17-04-2017), Tiffviz (15-01-2017)
Old 04-01-2017, 04:52 PM   #6
I suspect the same characteristic that makes them good at cleaning also gives them a somewhat grabby nature.
I also suspect that the fishscale cloths pick up a little bit of pile from any open loop cloths that may go in the wash at the same time.
Might have to give the e-cloth a go (which is just another variant of microfibre as far as I am aware) if the closed loop idea doesn't work.
Old 04-01-2017, 05:08 PM   #7
Ross
'Spec'ial B
Ross's Avatar
I am going to try an E cloth,tried loads of glass MF's and have yet to find one that works really well.
The Following User Says Thank You to Ross For This Useful Post:
shine247 (04-01-2017)
Old 04-01-2017, 05:15 PM   #8
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
Interesting Have a good Glass Towel im trying at the moment - close looped mircofibre always leaves fibres for me - fishscale are ok but dont always do a perfect job - a ecloth style cloth is what i have so will update a little more as i use it -
Old 04-01-2017, 05:21 PM   #9
neilmcl
Could always give the tried and tested scrunched up newspaper technique a go I suppose
Old 04-01-2017, 06:03 PM   #10
https://wo-wo.co.uk/collections/wo-w...lass-cloth-set
These are the only clothes I have found that really leave a perfect finish
And with 20% off for pack of three
