Old 06-01-2017, 08:00 PM   #11
Alan W
Alan W's Avatar
Originally Posted by A&J View Post
Yeah I wanted to comment earlier...
Considering how little clear coat there is on B pillars and how soft it is you only need a finishing polish with a soft pad (black for starters, then white if need to) so I agree with Gonz only using DJ Micro prime.
Jon H who used Megs UC...yeah it looks good but he removed way too much clear coat needed. Do that 2-3 times and youll burn through.
There hasn't been any clearcoat on any of the B pillars I've ever worked on.
They have just been uncoated high gloss plastic.
Alan W
Welshquattro1 (06-01-2017)
Old 06-01-2017, 08:12 PM   #12
fozzy
DW Reviewer
fozzy's Avatar
I used to use nothing more than Black hole on my old Mini pillars and it worked to perfection, they're all as soft as s*** so no need to do anything even slightly aggresive
fozzy is offline   Reply With Quote
Old 06-01-2017, 08:44 PM   #13
cleslie
cleslie's Avatar
I didn't realise it was clear coat. What is it made of? I thought it was a high gloss plastic.
Old 06-01-2017, 09:04 PM   #14
Alan W
Alan W's Avatar
It is high gloss plastic in my experience (see my reply above).
If the B pillars were clear coated the finish would be as hard as the paint on the body.
However, the finish is uncoated plastic which is soft by nature and hence why it marks easily.
Alan W
Old 06-01-2017, 09:13 PM   #15
Welshquattro1
Welshquattro1's Avatar
I agree with Alan W. My Audi ones are just High gloss plastic with no clear coat on them. I have thought about having them clear coated or even wrapped as they are a pain tbh
Welshquattro1 is offline   Reply With Quote
The Following User Says Thank You to Welshquattro1 For This Useful Post:
Alan W (06-01-2017)
Old 06-01-2017, 09:17 PM   #16
A&J
A&J's Avatar
Well I polished mine and experienced black paint transfer on only one side (EDIT: because i thought I over did it).
I have a 2010 Renault Scenic.
I thought it was down to the manufacturer.
Old 09-01-2017, 01:29 PM   #17
lawrenceSA
Alan W
The B-pillars are definitely clear coated. The reason the clear isn't as 'hard' as the rest of the car is you can't exactly bake plastic at the same heat you'd bake the metal in.
I have detailed many, many many VW's (>50) and the only time you will get black transfer onto the pad is when the clear has been compromised, mostly on the edges of the pillars.
Typically if you look at the pillars you will see they do not sit flush with each other and are not at same angle, and so unless some careful taping has been done, the edges always get hammered and the clear compromised.
Menzerna SF4000 on a black pad should be all that is needed. I;ve often used PF2300 on a white pad for really bad ones.
I even did some wetsanding on a set on a Range Rover sport which had been taken off road and has some deep scratches from the bush
lawrenceSA is online now   Reply With Quote
The Following User Says Thank You to lawrenceSA For This Useful Post:
great gonzo (09-01-2017)
Old 12-01-2017, 09:48 AM   #18
Leebo310
Leebo310's Avatar
I've used Chemical Guys Blacklight as an all in one via either white or yellow Rupes pads, depending on how bad the damage is.
Edit - the pillars must have some sort of clear on top otherwise you'd get paint transfer every time you polished. If it was just the pure soft black plastic then any bits removed from polishing would therefore show as black on the pad each time.
Old 12-01-2017, 01:44 PM   #19
Of course they have clear coat on gloss bi pillars, if the OP is picking up any black marks on his pad then he is catching the rubber edges of the pillars. When the car is painted the pillars are not attached, they are added on further on the production line, so that's why they are not as hard like the rest of the paint.
Old 12-01-2017, 03:48 PM   #20
great gonzo
great gonzo's Avatar
If you don't tape up well your pad might be picking up the rubbers that are running down the side if the pillars, this will make a mess of your pad!!
Gonz.
