Old 10-01-2017, 07:23 AM   #1
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
Cleaning Alcantara >Colourlock
From Colourlock
Spray the area
Wipe with Cloth
In case of stains, use a sponge and press cleaning foam
Clean the stains circularly with the foam
Results
Cleaning big surfaces: Wet the stained surface slightly with Alcantara & Textile Cleaner and immediately wipe gently with a terry cloth. Repeat if necessary.
Removing stains: Wet a sponge or a soft brush with some cleaner. Press foam out of the sponge. Clean the stained area in a circular motion. Then wipe with a damp cloth. Don`t rub too hard! Do not make it too wet! When stains can’t be removed, ask a professional upholstery cleaner before damaging the material.
Fresh stains should be absorbed immediately with an absorbent, clean cloth. Either dab or work from outside of the stain to the centre. Do not rub too hard. In case of big stains, work from seam to seam.
For greasy and waxy stains use COLOURLOCK Leather Cleaning Spirit. Work carefully. Test in a hidden area first.
To reduce future soiling and stains, protect the surface with COLOURLOCK Waterproofing for Leather & Textiles. Heat should be kept away from Alcantara. For example cigarette burns cause irreparable damages in Alcantara.
Alcantara is prone to pilling. Abrasion causes the fibres to develop into small spherical nodules. If the surface is not too damaged, it can be restored with the COLOURLOCK Leather Sanding Pad (see video). In case the material is too damaged, it has to be replaced.
Video
WHIZZER is online now   Reply With Quote
The Following 3 Users Say Thank You to WHIZZER For This Useful Post:
Actrosman (22-02-2018), todds (10-01-2017), Welshquattro1 (10-01-2017)
Old 22-02-2018, 04:59 PM   #2
mb1
does this deep clean Alcantara.
Old 22-02-2018, 05:01 PM   #3
mb1
or likely soiled dirty.
