Go Back   Detailing World > Traders > Clean and Shiny
Clean and Shiny Detailing Products and Bespoke Detailing Services - GTechniq Accredited - Walk in Customers Welcome. Call us on 0330 22 33 777 www.cleanandshiny.co.uk
Products Available By: 3M - Angelwax - Auto Finesse - Bilthamber - Black Mamba - Britemax - California Scents - Chemical Guys - Collinite - Colourlock - Detail Factory - Dooka - Dodo Juice - EZ - Flex - Flexipads - Gtechniq - Grit Guard - Gyeon - Koch Chemie - Kwazar - Meguiars Pro/Consumer/Detailer Range - Microfiber Madness - Orchard Autocare - Renovo - Rupes - Scratch Shield - Snow Foam Lances - Scholl Concepts - Solution Finish - Spies Hecker - Stoner - Valet Pro - Wheel Woolies - WoWo's - Zaino.
Old 16-11-2017, 01:16 PM   #1
Clean and Shiny
Approved Trader
basket **NEW PRODUCT ALERT** Scholl Concepts EcoFix
Five new polishing compounds in an exciting new line-up…
Scholl Concepts have just released their brand new, competitively-priced and stunningly effective range of products
Introducing the Scholl Concepts Ecofix Finish System.
Tests show the new Ecofix Finish System really does have the double wow factor - both in performance and price!
Pricing starts at just £13.65 for a 1 Litre Bottle and only £4.15 for a Pad. These are aimed and been developed for the detailing and car enthusiast market and not suitable for the use in body shops. For professional painters, the premium ‘S’ Compounds are recommended.
We have recently used the compounds on a Land Rover Discovery and found the products to work really well in both removing fine swirls (This was a new car detail) and also in refining.
More information about each product below and you can view them on our website here - https://www.cleanandshiny.co.uk/sear...oduct&q=Ecofix
E1500
Cutting power: Extra Heavy
Gloss Level: High
Sanding Paper: P1500
The Cutting Compound can be applied with all Scholl Polishing Pads. For best results, we recommend the use of the Universal Polishing Pad orange or the coarse white pad. It can be applied with a rotary polisher as well as orbital polishing machines.
E2000
Cutting Power: Heavy
Gloss Level: High
Sanding Paper: P2000
E2000 can be used with all Scholl Polishing Pads. To achieve an excellent high-gloss finish in just one single step on fresh paintwork, we recommend using the hard, white Polishing Pad. On used and weathered surfaces best results can be achieved with the orange Universal Pad. The E2000 was designed for applications with rotary polishers. However, it can also be applied easily with a modern high-stroke dual action polisher.
E3000
Cutting Power: Fine
Gloss Level: Extreme
Sanding Paper: P3000
E3000 can generally be applied with all SchollPolishing Pads. For the best , results we recommend the use of the universal Polishing Pad orange or the soft black Pad. It can be applied with a rotary as well as an orbital polishing machines.
E-WAX
Cutting Power: Microfine
Protection Level: Brilliant
In cases of severe scratched paintwork, we recommend the use of a Cutting Compound like E1500 or E2000 prior to the application of E-Wax. Generally we advise applying E-Wax by hand using our soft black Application Puck. Distribute the wax evenly and in a circular motion on the paint surface; let it dry and wipe off the residue with our seamless, red MicroPLUS Finishing Cloth. E-Wax can also be applied by machine using an orbital or rotary polisher and the soft black Polishing Pad.
E-ALL IN ONE
Gloss Level: Brilliant
Protection Level: High
The E-ALL IN ONE can broadly be used with all Scholl Polishing Pads. We recommend our abrasive TopWool Polishing Pad for severely weathered or heavily scratched surfaces. For intermediate paint perfection, use the open-pored white Polishing Pad. To get a perfect final finish we advise the use of the extra soft black Pad.
Ecofix Finish System Pads
Scholl Concepts Ecofix pads as recommended to work perfectly with the new Ecofix compounds and wax - Orange, White, Soft Black, and TopWool.
Clean and Shiny is offline   Reply With Quote
The Following 4 Users Say Thank You to Clean and Shiny For This Useful Post:
BoroDave74 (16-11-2017), Brian1612 (16-11-2017), ronwash (17-11-2017), Short1e (17-11-2017)
Old 17-11-2017, 03:52 PM   #2
Just curious why these are not recommended for bodyshop use? Do they contain silicones, or are they just keen to maintain the margins on those other products I wonder?!
Old 18-11-2017, 07:40 PM   #3
Yellow Dave
Yellow Dave's Avatar
Will the pads work ok with the original S series compounds
Old 18-11-2017, 07:43 PM   #4
Clean and Shiny
Approved Trader
That’s something that I will find out for you. I don’t want to give wrong information so will check with Scholl.
The Following User Says Thank You to Clean and Shiny For This Useful Post:
steelghost (18-11-2017)
Old 18-11-2017, 07:44 PM   #5
Clean and Shiny
Approved Trader
I can’t see why not.
Yellow Dave (19-11-2017)
Old 27-11-2017, 04:18 PM   #6
Atkinson91
Yeah I'd like to know what the difference is between the ecofix and the S range....I see that the new ecofix range isn't bodysuit safe, assuming as someotuer people are, this contains silicone?
What other advantages are their to this over the S range?
Old 27-11-2017, 08:28 PM   #7
Karl woods
Karl woods's Avatar
https://flic.kr/p/21RryvQ
Yes defo contains silicone , I have only had limited use of 1500 so far but I quite like it , well lubricated and good working time on the paint I have used it on.
Karl woods is offline   Reply With Quote
Old 28-11-2017, 10:20 AM   #8
Clean and Shiny
Approved Trader
Targeting a detailer audience only has enabled Scholl Concepts to develop some unique formulations with other technologies (silicone oils) that cannot be used in paint shops, but that bring about different benefits for this sector of the market.
The whole range – both pads and the compound/waxes - is very easy on the pocket. The low-cost, no frills yet quality foam and lambswool Ecofix pad range guarantee results as they have been developed for use in conjunction with the economic Ecofix formulations.
The products are very quick, clean and easy to use and, like the S range, give impressive results. And there’s something for all levels, from pure protection only (E-Wax) to the fast fix cut and wax product E-AllinOne. For regular maintenance work and customers not wanting to pay for a full correction, these can also be great go-to products.
The range provides an alternative choice to the S range, and will have a place in the mobile or pro detailer armoury alongside the highly regarded ‘S’ products.
Old 25-12-2017, 02:19 AM   #9
Eurogloss
International Supporter
Eurogloss's Avatar
From a professional point of view I don't like that they contain silicone !
That's why I find Sonax superior to this Scholl Concepts Range !
Eurogloss is offline   Reply With Quote
Old 25-12-2017, 04:12 AM   #10
Reading into it essentially it's a range for home use so the silicones shouldn't matter should it? Looks like a cracking range especially for the price.
sistersvisions (07-02-2018)
