Old 09-07-2017, 06:59 AM   #1
joshb
joshb's Avatar
Send a message via AIM to joshb
Autogloss rinse
Hi could autogloss rinse be used throught a foam lance? If so what would you reccomend dilution ratio? Cheers
joshb is offline   Reply With Quote
Old 11-07-2017, 10:55 PM   #2
Clarkey-88
Clarkey-88's Avatar
Nick_mcuk has tried it through a lance. This was his comment in an Autogloss Rinse thread I started last year. Not sure how he got on, or even bothered with a second test though
Originally Posted by nick_mcuk View Post
Chaps...I got the chance to wash the 208 this afternoon while my little lad was asleep. so instead of applying the AutoGloss Rinse in the traditional manner I decided to see what it would do in the foam lance.
Now I have applied a certain new hydrophobic foam and been super impressed so wanted to see how the AutoGloss Rinse worked like this so I put about 150ml in a 500ml AutoGlym spray bottle and filled up with water (this was way to much I know but this was a test after all!!) I have been using it for years in the traditional method as might have said previously in this thread.
So the results shocked me first off it foamed up quite well and the entire car went white! Left it to dwell for a couple of minutes then literally just pressure washed it off....it left a lovely shiny surface with beading and sheeting not quite the same as the traditional method but interesting still the same...will try again next week and use less but first tests show it does work!
Clarkey-88 is offline   Reply With Quote
Old 12-07-2017, 07:32 AM   #3
Morph78
Morph78's Avatar
I apply Autogloss rinse through one of these:
http://www.chemicalguys.com/Foam_Bla..._p/hol_181.htm
After every wash, let it dwell and then dry off.
Seems to leave a nice glossy finish and some protection, rain water beads nicely just not tight beads like you would get with a wax.
This is the only protection the car gets, no polish or wax is applied.
Works for me, quick, easy and cheap.
Morph78 is offline   Reply With Quote
Old 16-07-2017, 09:19 AM   #4
Radish293
Radish293's Avatar
I was sold on this stuff after watching the awesome Autoglym video of it repelling water. However it doesn't perform like that on my cars. I'm sure it works better on paint without the level of LSP that most of us on here like. It does seem to leave a level of Gloss. You can't complain about the value for money 1:100 at maximum dilution 5l is going to last for ever.
Old 16-07-2017, 08:20 PM   #5
Clarkey-88
Clarkey-88's Avatar
1:100 is what Autoglym recommend, but I use it a lot stronger then that and it works brilliantly. In a 500ml bottle, try 50ml of product and fill the rest with water and see how that works, if not then add more until you're happy. If it's too strong it'll end up leaving stains on the paint, they will come off easy with a wipe of qd though
Old 17-07-2017, 08:02 AM   #6
Radish293
Radish293's Avatar
I will try it a bit stronger to see what difference it makes. Not sure when it's gone I would buy more.
Old 19-07-2017, 10:38 PM   #7
Clarkey-88
Clarkey-88's Avatar
Let us know how you get on
Old 19-07-2017, 10:52 PM   #8
Cornish
Cornish's Avatar
I put a small amount in a two gallon bucket after washing car and tip over.
The water sheets off fantastically, leaving me with hardly any drying to do
Cornish is offline   Reply With Quote
Old 20-07-2017, 10:50 AM   #9
Clarkey-88
Clarkey-88's Avatar
I've never thought of using it that way. I suppose the water would sheet much better by poring water rather then using a jet was. I might have to try it
Old 20-07-2017, 06:57 PM   #10
Radish293
Radish293's Avatar
I put 100ml in 1l of water and washed as normal before spraying the entire car with the mix. It cased the remaining rinse water to chump and run off the sides before a rinsed it again. Still needed to dry the car. Better performance with stronger mix.
