Old 16-06-2017, 12:40 PM   #1
Grunty
Nilfisk C130.1 Low Pressure
I have a 3 year old Nilfisk C130.1 Last couple of uses pressure has been much lower than normal and if it is left powered with the water attached, but not being used for about 20 seconds or more it starts to pulse almost every 5 seconds.
Its never got frosted as it stays in my garage and is always rinsed through after use (20 seconds or so with no water attached).
Any ideas?
Grunty is offline   Reply With Quote
Old 16-06-2017, 12:48 PM   #2
hardyd44
You got any leaks from the outlet hose/gun ? sounds like it is sensing demand and trying to pressurize the hose
first thoughts only
hardyd44 is offline   Reply With Quote
Old 16-06-2017, 12:51 PM   #3
Grunty
No leaks from the gun its self, but when you take the lance off the gun and squeeze for water it isn't what i would call a steady stream of water you get, its spraying quite a bit. Used to be a steady stream.
Old 16-06-2017, 02:16 PM   #4
OvEr_KiLL
OvEr_KiLL's Avatar
see if the filter is full of limescale. unscrew the part the hosepipe clips on to and pull it out with some long nose pliers and let it sit in white vinegar over night and also check the o ring on the hose that clips in the gun
Grunty (17-06-2017)
Old 16-06-2017, 02:20 PM   #5
Mother-Goose
Mother-Goose's Avatar
Just to clarify this point - it needs to be white vinegar.
Mother-Goose is offline   Reply With Quote
Old 16-06-2017, 03:41 PM   #6
OvEr_KiLL
OvEr_KiLL's Avatar
eh?? i said '' white vinegar ''
Old 17-06-2017, 10:41 AM   #7
Grunty
I have checked all the o rings that I can see and they all look fine, I have also unscrewed where the hose attaches and there doesn't seem to be a filter there. Quite a bit of limescale build up though.
This is what I have when I unscrew the hose attachment
Old 17-06-2017, 05:25 PM   #8
OvEr_KiLL
OvEr_KiLL's Avatar
get that cleaned out best you can with a microfibre and white vinegar. dip the cloth in it push it in and twist it around and yes there should be a filter in there that will pull out with nose pliers but i cant tell with the ammount of limescale in it. thats what i did recently
and let the filter soak in white vinegar over night
heres my thread and you can see the filter.
http://www.detailingworld.co.uk/foru...d.php?t=394904
Grunty (17-06-2017)
Old 17-06-2017, 05:40 PM   #9
joe39
joe39's Avatar
Similar issue...
Hi there, may be of help...
I have a 150-2 Nilfisk which recently started losing pressure. I contacted Nilfisk who asked me to remove the HoseLock (non return) quick connect from the water supply hose to the machine. I informed them that this had been on the machine from new (1.5 years) but they insisted this was the problem. Unconvinced I relaced it with a straight through quick conect - Hey ho problem solved. Something to do with a back pressure build up within the machine. Worth a try!!
Cheers Joe.
joe39 is offline   Reply With Quote
The Following User Says Thank You to joe39 For This Useful Post:
Grunty (17-06-2017)
Old 17-06-2017, 06:14 PM   #10
Grunty
There is definitely no filter in mine. Strange, I've had it from new.
Anyway, will try and clean what is there with white vinegar and if that fails new connection, as it is a non return that is on it.
