Go Back   Detailing World > Lifestyle > The Tech & Gadget Zone
The Tech & Gadget Zone Gadgety, Techy or even a Techy Gadget! Stick a post in here! Sponsored by SlimsDetailing - inspired by anybody who has a car they love and care for
Old 17-12-2017, 08:25 PM   #1
Darlofan
Removing a hard drive
Bought a new laptop recently as old one was on its way out.
Just gone to switch old one on and it won't come on. Battery is dead and charger is not charging it!!
Can I remove the hard drive, connect it to something(simple) to get files off it or is it a job for a professional?
Darlofan is offline   Reply With Quote
Old 17-12-2017, 08:29 PM   #2
Yes as a general answer, you can...
Take it out, connect it up and you should be able to see it as a drive and then go find your files - this is what I did with wife's old laptop HDD, but we didn't have and encryption etc on it...
I bought a HDD caddy and fitted it in this, pulled the files off it, wiped it completely and have it as a spare drive now...
Darlofan (17-12-2017)
Old 17-12-2017, 08:31 PM   #3
dholdi
dholdi's Avatar
If you don't have another pc to plug it into you could get a cheap caddy and do it that way.
https://www.ebay.co.uk/itm/Hard-Disk...YAAOSwWxNYwnEN
dholdi is offline   Reply With Quote
The Following User Says Thank You to dholdi For This Useful Post:
Old 17-12-2017, 09:35 PM   #4
Darlofan
Cheers guys. If I understand that correctly, I can remove the old drive pop it in that caddy suggested and plug that into my new laptop and shift data over to laptop?
I can then use the caddy as an external drive? That would be handy as I've been looking at an external drive for backing up as I've never done it!!!!
Old 17-12-2017, 09:38 PM   #5
James_R
James_R's Avatar
Exactly.
This is just what I did with my old windows laptop.
Took the drive out, put it in a caddy, plugged it into the usb port on the new laptop, copied that data over, then formatted the old drive and used it as a backup drive
James_R is offline   Reply With Quote
The Following User Says Thank You to James_R For This Useful Post:
Old 17-12-2017, 09:45 PM   #6
Darlofan
Originally Posted by James_R View Post
Exactly.
Excellent, thanks for that. Much difference in caddys or are they all much of a muchness?
Old 17-12-2017, 09:49 PM   #7
James_R
James_R's Avatar
I picked up PNY one from Currys.
Think it was about £14
You could get cheaper but I like the look of the PNY
Old 17-12-2017, 10:01 PM   #8
Mikesphotaes
Mikesphotaes's Avatar
Just make sure you earth yourself, by grasping a radiator, before you disconnect the actual drive.
Mikesphotaes is offline   Reply With Quote
The Following User Says Thank You to Mikesphotaes For This Useful Post:
Darlofan (18-12-2017)
Old 18-12-2017, 11:31 AM   #9
GleemSpray
GleemSpray's Avatar
Exactly.
That is good advice, but I would add that an ex-laptop drive will almost certainly have a recovery partition hogging up to 20gb of disk space, that contains the laptop manufacturers recovery/restore files for restoring the laptop after a disasterous crash.
So... Having safely recovered your data and before you format the drive, run it through disk management in Windows to remove any unwanted partitions and release extra space. You should end up with a 100mb system reserved partition and the rest as useable space.
The format command alone wont recover this reserved space.
Sent from my HTC 10 using Tapatalk
GleemSpray is offline   Reply With Quote
The Following User Says Thank You to GleemSpray For This Useful Post:
James_R (21-12-2017)
