Old 26-12-2017, 11:11 AM   #1
shy-talk
shy-talk's Avatar
In-line water pump.
Can anyone recommend a inline water pump so I can connect my water butt to my pw,for some reason my k5 won’t fire up with just gravity feed even though the W/butt is higher than my pw,I have to connect hosepipe from tap to fire up then quickly change to hose from tap to w/butt but if I let go of trigger on pw I have to repeat process again which is annoying.
Andy.
shy-talk is offline   Reply With Quote
Old 26-12-2017, 02:09 PM   #2
shy-talk
shy-talk's Avatar
I’m sure this will do me,it’s just to help the water flow
https://www.ebay.co.uk/itm/DC12V-60W...19.m1438.l2649
Andy
Old 26-12-2017, 02:17 PM   #3
dholdi
dholdi's Avatar
That's 12v so you will need to run it off a battery or a power supply.
Old 26-12-2017, 02:53 PM   #4
fatdazza
Your karcher needs just over 8 litres per minute so the 12 volt pump will not help as it seems to be rated 5 litres per minute
Old 26-12-2017, 03:39 PM   #5
trv8
The Karcher K5 should work from a water butt without an additional pump......
https://pressurewasherreviewer.co.uk...washer-bucket/
http://www.halfords.com/motoring/car...r-suction-hose
trv8 is offline   Reply With Quote
The Following User Says Thank You to trv8 For This Useful Post:
shy-talk (26-12-2017)
Old 26-12-2017, 03:56 PM   #6
shy-talk
shy-talk's Avatar
Thanks trv8,,Ive got the suction hose but Ive just been connecting hose from butt,,I wouldn’t have thought it made any difference but it must.
Andy
The Following User Says Thank You to shy-talk For This Useful Post:
trv8 (26-12-2017)
Old 26-12-2017, 04:43 PM   #7
How long is the hose between the butt and the PW? Needs to be as short as possible.
steelghost is online now   Reply With Quote
Old 26-12-2017, 04:49 PM   #8
fatdazza
To get the best flow from your water butt to the pw, the shorter and fatter the pipe the better
Old 26-12-2017, 05:46 PM   #9
http://www.detailingworld.co.uk/foru...d.php?t=369407
http://www.detailingworld.co.uk/foru...d.php?t=386908
Some useful reading on this topic
Please bear in mind that running a pressure washer on an insufficient water supply is really bad for the high pressure pump.
Old 26-12-2017, 09:55 PM   #10
Kenan
I'v got a K4 with that hose, you have to "prime" the hose. You need water in the hose to get the pressure washer started, I submerge it in the water butt first to fill it up.
Kenan is offline   Reply With Quote
