Old 05-05-2017, 11:26 PM   #1
Soapybubbles
Soapybubbles's Avatar
Blue roll holder ideas
Looking for some ideas to wall mount blue roll holder in my garage?
Was thinking of maybe an older metal curtain pole with mounting hangers either side?
Soapybubbles is online now   Reply With Quote
Old 05-05-2017, 11:34 PM   #2
macca666
macca666's Avatar
Not a suggestion for the holder sorry but I buy kitchen roll from Costco which I find works just as well as blue roll and when you buy in packs of 12 works out cheaper.
Means as well I just sit an individual roll on my workbench so don't need a holder.
Your suggestion sounds good though as I'm sure you'd be able to cut a curtain pole holder down to size
Soapybubbles (05-05-2017)
Old 05-05-2017, 11:43 PM   #3
nbray67
nbray67's Avatar
I have mine on a curtain pole.
If the rolls are quite wide/thick, they may not fit on as curtain poles don't stand off the wall too much.
The Following User Says Thank You to nbray67 For This Useful Post:
Old 06-05-2017, 12:03 AM   #4
Jon Neal
Mine is just hanging on a piece of cable from the roof
Jon Neal is offline   Reply With Quote
The Following User Says Thank You to Jon Neal For This Useful Post:
Soapybubbles (06-05-2017)
Old 06-05-2017, 11:17 AM   #5
dchapman88
dchapman88's Avatar
I made two brackets out of softwood and fixed them to a softwood backing piece. Cut holes in the two brackets and put dowel through.
It's attached to the wall and is right next to my workbench for when I need it
dchapman88 is online now   Reply With Quote
Old 06-05-2017, 11:20 AM   #6
shl-kelso
I use a "proper" centre feed dispenser mounted on the wall.
shl-kelso is offline   Reply With Quote
Old 06-05-2017, 02:31 PM   #7
baxlin
baxlin's Avatar
I use 2, one just slid onto a piece of softwood screwed to one of the garage rafters, the other on a piece of tubing with wire through it, each end of the wire fastened to a rafter. Both no cost, and both work well, the one on the tube runs freer, but the other is dead easy to remove to take to where I'm working if not in the garage.
baxlin is offline   Reply With Quote
The Following User Says Thank You to baxlin For This Useful Post:
Old 06-05-2017, 03:39 PM   #8
Soapybubbles
Something very satisfying about making up your own tool at little cost....!
Thanks for all replies so far
Old 13-05-2017, 09:23 AM   #9
Soapybubbles
Temporary install with some single core cable! Works perfect though
The Following 2 Users Say Thank You to Soapybubbles For This Useful Post:
AndyN01 (13-05-2017), steelghost (13-05-2017)
Old 13-05-2017, 11:31 AM   #10
Like it, might have to borrow that idea
Soapybubbles (13-05-2017)
