Old 15-07-2017, 11:06 AM   #11
neilmcl
I bought the following http://www.ebay.co.uk/itm/Nilfisk-Pr...72.m2749.l2649 and I've seen them cheaper. Literally to 5 mins to sort the issue out.
The Following 3 Users Say Thank You to neilmcl For This Useful Post:
dellwood33 (15-07-2017), OvEr_KiLL (15-07-2017), Slammedorion (15-07-2017)
Old 15-07-2017, 07:55 PM   #12
ffrs1444
ffrs1444's Avatar
Get rid and get a c110 I had loads of problems with my old C120 never a issue with the c110
ffrs1444 is online now   Reply With Quote
Old 15-07-2017, 08:53 PM   #13
OvEr_KiLL
OvEr_KiLL's Avatar
get rid of it when he probably only needs a o ring somewhere that is cheaper than buying a c110..great!
its pulsing because its trying to build up pressure and cant. change the o rings
OvEr_KiLL is online now   Reply With Quote
Old 15-07-2017, 10:05 PM   #14
neilmcl
Bit OTT for what could probably be a very simple and cheap fix don't you think.
The Following User Says Thank You to neilmcl For This Useful Post:
Old 15-07-2017, 11:31 PM   #15
Slammedorion
Slammedorion's Avatar
I've ordered them cheers
Slammedorion is offline   Reply With Quote
Old 17-07-2017, 12:09 PM   #16
Leebo310
Leebo310's Avatar
Presume it's outside of the 2 year warranty?
The Following User Says Thank You to Leebo310 For This Useful Post:
Slammedorion (18-07-2017)
Old 17-07-2017, 01:18 PM   #17
Mother-Goose
Mother-Goose's Avatar
I remember seeing in another thread that someone worked out that it was the stop flow connector on the hosepipe that was causing it - if the o-rings don't solve it do check that out as well (of course, if you don't have those connectors anywhere in the setup then it won't be that!)
Mother-Goose is offline   Reply With Quote
The Following User Says Thank You to Mother-Goose For This Useful Post:
Old 20-07-2017, 12:53 PM   #18
Slammedorion
I've replaced the seals and it's made no difference...
Will need to open it up and take a look once my long reach torx screw drivers arrive
Any other ideas?
Anything I can take apart and check its clean, or and other seals inside that can be changed, or is it likely to be the pressure switch?
Old 02-08-2017, 08:40 AM   #19
scooobydont
How old is it? I have just had the same issue with my c110. It is just over a year old and has a 3 year warranty (I think). I emailed Nilfisk and after exchanging a few details they are sending me a new one under warranty.
Old 30-08-2017, 11:32 AM   #20
scooobydont
That my warranty replacement arrived . They dont even want the old one back.
Great service from Nilfisk.
