Old 27-11-2016, 01:30 PM   #1
RobinsonNoah
Supercharging my Classic Mini
Over double the original out put just simply wasn't enough, so it's time to bolt a whopping Eaton supercharger and Weber carb, although in theory everything sounds simple, lost of little bits will take time.
The Supercharger kit is supplied by Stuart Gurr, of Vmax-Scart, the same person who's been making kits for over a decade and notably supplied the supercharger kit for the Mighty Car Mods car.
This kit, is slightly different, it utilises a weber 40, as opposed to the SU carb that Mini's originally had.
Now my car made on Peter Baldwin's Dyno (Notoriously inaccurate), 102bhp. To give you a scale, my boss's 1380cc engine with twin HS4s, made 114bhp on the same dyno, and a colleagues 1380cc engine with Twins and a standard cylinder head made 94bhp.
I will say, 87cc down on those two means this thing is much more a rev happy engine than a larger bore. Peak power was at 5800rpm, Stuart estimates 130bhp, but we will see what his dyno says later on!
For those of you who haven't already seen my car, here's a winter wash post a I did a few weeks back; http://www.detailingworld.co.uk/foru...d.php?t=385863.
Read that? Good, we'll continue.
Right, the strip down, to fit the supercharger, obviously you need to drive it with a belt, problem being is, the breather on the timing cover rather gets in the way of that, stuart supplies a snazzy plug, but I had access to an early non breather timing cover to get past that.
DSC_0191 by NoahRobinson07, on Flickr
Either way, the timing cover needs to come off, so first things first. Rad out.
DSC_0192 by NoahRobinson07, on Flickr
Sounds easy, but with the cowling, and not wanting to scratch my paint, I took my time, of course. All the coolant went everywhere. Expect the drain pan. Standard.
The rad is held in with two fixings at the top, and one through the cowling at the bottom, if you're good you can get the rad and cowling out in one piece. I am that good, but once it was out, undid the cowling as it needs re-painting.
DSC_0193 by NoahRobinson07, on Flickr
Once the rad was out, I took the opportunity to remove the alternator, another fine art, to not scratch the paint! You could do it without removing the alternator, but it gives better access to the front bolts of the timing cover.
Next up in the remove it list, is the inlet manifold and carb assembly. Another, easy job if you've done this before, 1/4" ratchet on a short extension, with a 1/2" socket, I still need to whip the exhaust manifold off to change the gasket but, no hurry.
DSC_0194 by NoahRobinson07, on Flickr
And today's final job was to remove the starter, 9/16 spanner for the top bolt and a socket on an extension for the bottom, which reveals my lovely lightened flywheel.
DSC_0195 by NoahRobinson07, on Flickr
As you can see, the dirt on the subframe cleans of lovely, so next week's job is clean the engine bay, and then get the engine mount of and change the timing cover, I've got the well seal at the ready!
DSC_0196 by NoahRobinson07, on Flickr
DSC_0197 by NoahRobinson07, on Flickr
Amongst other jobs, I want to find a new plan for these headlamp connectors as they're ****.
DSC_0198 by NoahRobinson07, on Flickr
DSC_0199 by NoahRobinson07, on Flickr
And I want to re-do my dash cards, thanks for reading.
Noah
RobinsonNoah is offline   Reply With Quote
The Following 10 Users Say Thank You to RobinsonNoah For This Useful Post:
Cookies (30-11-2016), ed87 (12-12-2016), JB052 (04-12-2016), JoeyJoeJo (04-12-2016), Mr Gurn (22-01-2017), SBM (31-01-2017), Sicskate (27-11-2016), sshooie (27-11-2016), stonejedi (30-11-2016), streaky (10-12-2016)
Old 27-11-2016, 01:39 PM   #2
Sicskate
Sicskate's Avatar
This is going to be an awesome project
Have you watched the mighty car mods mini supercharger project??
Old 27-11-2016, 01:44 PM   #3
RobinsonNoah
Cheers bud. I did watch it, they went all out running it on ethanol and injection. This is just a good old fashioned 40DCOE. :-)
Old 28-11-2016, 09:35 PM   #4
RobinsonNoah
Supercharger arrives on Wednesday, I'm working Saturday so Sunday I can crack on, want to get the crank pulley off. Sounds easy, but I sense it's not going to come off happy. Never know, it may just pop off! (Probably not!)
WellSeal is at the ready for the timing cover and a genuine Rover Klinger gasket, its that rubberised gasket material. For those who haven't used or don't know what well seal is, its an old school gasket jointing material. It's the sort of thing your grandad would have in his shed. The warning label on the back states 'Known to cause cancer', bugger it. At least the timing cover won't leak!
Old 30-11-2016, 07:22 PM   #5
RobinsonNoah
Parts arrived today...
DSC_0210 by NoahRobinson07, on Flickr
DSC_0208 by NoahRobinson07, on Flickr
DSC_0207 by NoahRobinson07, on Flickr
DSC_0203 by NoahRobinson07, on Flickr
The Following User Says Thank You to RobinsonNoah For This Useful Post:
Sicskate (04-12-2016)
Old 30-11-2016, 07:35 PM   #6
tones61
tones61's Avatar
like button pressed
tones61 is offline   Reply With Quote
The Following User Says Thank You to tones61 For This Useful Post:
RobinsonNoah (30-11-2016)
Old 30-11-2016, 08:02 PM   #7
J306TD
J306TD's Avatar
Send a message via MSN to J306TD
Just WOW
Sent from my Samsung Galaxy S7
J306TD is offline   Reply With Quote
The Following User Says Thank You to J306TD For This Useful Post:
Old 30-11-2016, 08:12 PM   #8
Cookies
Cookies's Avatar
That's a lovely wee classic mini. I'd love to get a run in it after the charger is fitted. That'll be wicked.
Cooks
Sent from my D6603
Old 30-11-2016, 08:27 PM   #9
willywonker
willywonker's Avatar
Wow this looks good, can't wait to see how you get on. Miss my Mini, wish I'd never sold it, so much fun!
What 'box are you running to cope with the extra poke?
Love the wheels btw absolutely best wheels for a Mini.
willywonker is offline   Reply With Quote
Old 30-11-2016, 08:27 PM   #10
transtek
transtek's Avatar
After watching the MightyCarMods supercharged JDM Mini, this is going to be cool as f!
Can't wait to see more.
transtek is offline   Reply With Quote
The Following User Says Thank You to transtek For This Useful Post:
classic car, cooper, mini, supercharged
