Old 15-11-2018, 09:26 PM   #1
jdo
Question Detail Factory Ultra-Soft Detailing Brush - Large vs Small
These appear to be a defacto standard recommendation for both exterior and interior use. Those of you that have them and have used them in anger - thoughts on the large versus the small? Ideally want to get one of these for the interior and one for the exterior but having not actually seen them nor used them I can't judge what size is best for each use. Thanks
jdo is offline   Reply With Quote
Old 15-11-2018, 09:35 PM   #2
matty.13
I use the small for the interior and bigger on for outside the car. You could use a big on on the inside but the the small I would not use for out side.
matty.13 is offline   Reply With Quote
The Following User Says Thank You to matty.13 For This Useful Post:
jdo (15-11-2018)
Old 17-11-2018, 10:44 PM   #3
pump
pump's Avatar
pump is offline   Reply With Quote
The Following User Says Thank You to pump For This Useful Post:
jdo (20-11-2018)
Old 18-11-2018, 12:09 PM   #4
neilmcl
I have them both and use the large one for the exterior only and use the small one on those delicate areas around the dash and vents in conjunction with my vacuum. Definitely recommend them.
I also have a standard set of detailing brushes, Envy brushes I believe, and use these for less delicate work, eg, wheels etc.
The Following User Says Thank You to neilmcl For This Useful Post:
jdo (20-11-2018)
Old 19-11-2018, 09:35 AM   #5
Stoner
Stoner's Avatar
I only have the small one which is great for the inside but only on the dash/sat nav etc. I have a couple of Vikan brushes for the carpet and a leather brush for the seats. I also use cheaper brushes for the outside on the trim only and never let a brush near the paintwork.
Wheel woolies and a large "face" brush for the wheels complete the set
Stoner is offline   Reply With Quote
The Following User Says Thank You to Stoner For This Useful Post:
jdo (20-11-2018)
