Old 31-10-2012, 11:43 AM   #11
derbigofast
derbigofast's Avatar
through the machine ive never had a problem and it even partially dries them for you
Old 03-11-2012, 10:01 PM   #12
Lupostef
Lupostef's Avatar
Wack em in the washing machine after every use mate.
Lupostef is offline   Reply With Quote
Old 04-11-2012, 08:47 PM   #13
VenomUK
VenomUK's Avatar
Do you put any liquid in the washer or not?
VenomUK is offline   Reply With Quote
Old 04-11-2012, 09:30 PM   #14
DJ X-Ray
DJ X-Ray's Avatar
Location: Straight outta London...in an Audi. Maxin' with fellow OG's, ballers and macks;)
Washing machine for me.After every use
DJ X-Ray is offline   Reply With Quote
Old 05-01-2013, 12:22 AM   #15
Wayno
Wayno's Avatar
Is it ok to wash them under warm running water and need them to get the polish out then give them a good rinse and then flick them getting the remaining water out?
I've been doing this and then letting them dry naturally at room temp.
Also, after the first pass and any second passes made how much more polish should I add to the pad for the next area? I've been using 5 dots initially and then 3 dots thereafter.
What are people's views with these queries?
Wayno is offline   Reply With Quote
Old 10-01-2013, 06:41 PM   #16
Sheep
This is totally fine, and probably on the safe side from what I've gathered. you can use cleaners and machines to wash the pads out, so hands is perfectly safe.
Also totally safe.
I've heard it's different for different types of polish. Deminishing abbrasives just need 3-4 pea sized dots for a section, while SMAT polishes need the pad primed first, by adding a thin, even coat of polsih to the face of the pad, followed by a 2 pea sized dots. Might be worth checking what type of polish it is you're using to see which process works best for you.
Also, you'll need to clean up the pad for deminishing abbrassives as it can become clogged before a car is done. I've done it by wiping with a MF one I feel it's too wet (usually after 4-5 sections). Apparently you can brush it as well, but not sure how this will get wet polish out of a pad. If someone could chime in to help, that would be great. I'm not sure how you maintain the pads with SMAT polishes.
Old 28-11-2015, 10:21 PM   #17
Mpv2k3
Mpv2k3's Avatar
If putting pads in the washing machine.....what setting? Temp etc
Mpv2k3 is offline   Reply With Quote
Old 29-11-2015, 12:29 PM   #18
FallenAngel
FallenAngel's Avatar
On a low heat, max 40C better on 30C. Lower spin cyle, liquid detergent and air dry. Finished
FallenAngel is offline   Reply With Quote
The Following User Says Thank You to FallenAngel For This Useful Post:
Mpv2k3 (29-11-2015)
Old 29-11-2015, 12:42 PM   #19
FrontRowForward
Just the thread I needed, its clarified a couple of things. Cheers.
FrontRowForward is offline   Reply With Quote
Old 03-12-2015, 12:58 AM   #20
-Ash-ST
How long do pads last. I've just brought Chem guys and I would wash them on a lower temp in the washing machine then air dry them on the radiators for example.
After time my megs pads split so keeping an eye on this
-Ash-ST is offline   Reply With Quote
