Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bouncers
Old 24-02-2017, 01:23 PM   #1
The_Bouncer
DW Sponsor - 'No, you can't come in'
The_Bouncer's Avatar
Location: It isnt all fluffy clouds, flash cars and big cash all the time
SUPERSIZE ME !! - PLUS £230+ Giveaway :)
ok, a thread to give you the heads up on a few products that we have launched recently in case you have not seen them and to tell you that these are available in trade 5 Litre Sizes.
Add a comment below and using a random number selector, I am also giving away 1x 5 Litre of each product to a lucky winner. - so to recap one person will win a 5 Litre D&D, Slick Mick, Bead Juice & Look Sharp. - worth over £238.00 !!
Comp will end at 23.59 GMT on Tues 28th Feb and I will announce winner on 1st March. - For shipping purposes - only UK based members only (sorry)
Done & Dusted Quick Detailer RRP Inc VAT
500ml - £12.99 inc trigger
1000ml - £22.99
5000ml - £79.95
Bouncer's Quick Detailer, the aim was to create the ideal quick detailer and gloss enhancer that is simple to use, doesn't smear and is friendly on all surfaces and leaves protection behind with every wipe. We think that this has been achieved. Done & Dusted is an all-rounder with pleasing results on paintwork, glass, plastics, wheels and trims.
Bouncer’s ‘Done & Dusted’ has caused quite a stir, during a soft launch of the product last year it climbed the charts by storm and was subsequently placed on the Detailing World QD product of the year nominations. A water based, cross polymer based QD it offers high gloss on paintwork, glass and piano style plastics. It can also be used on interior plastics. It offers anti static properties and is anti smear. It’s absolute speed of use combined with a layer of protection and immediate gloss levels have placed this QD at the top of a lot of professional detailers ‘go to ‘ list.
Features
- Ideal for use on a number of surfaces including paintwork, glass and plastics
- Nominated into product of the year Awards 2014
- Simple to use, Impressive gloss finish. Doesn't smear
- Compliments all waxes and sealants
- Amazing Sherbert Fizz aroma
Slick Mick Shampoo Inc VAT
500ml - £13.99 inc fliptop cap
1000ml - £24.99
5000ml - £79.95
Slicker than a Dolphin wearing Raybans, smoother than a triple Gillette blade and safer than James May doing doughnuts in a 3 wheeler. Bouncer’s shampoo is a high concentrate blend with no fillers or added foaming agents.
Bouncer's Slick Mick Shampoo provides excellent cleaning ability and superb slickness across the paintwork. It is PH7 neutral so is product safe and wax safe. Used at a dilution rate of between 1-3 capfuls per 10 litre bucket (dependant on local water hardness) it offers outstanding value for money and falling in line with the brand offers the ‘famous’ ‘Fizz’ fragrance.
Features
- High concentrate blend
- No fillers or added foaming agents.
- PH7 neutral so is product safe and wax safe
- Super Slick.
Look Sharp - Glass Cleaner - RRP Inc VAT
500ml - £8.99 inc trigger
1000ml - £15.99 inc trigger
5000ml - £33.99
Bouncer's Look Sharp is a pre-mixed glass cleaner that will effortlessly and effectively clean vehicle glass without streaking or dusting
Spray lightly onto glass & remove using suitable buffing cloth. Use to remove dust/water marks and leave a streakfree, sharp, clean, crystal clear finish. Can be diluted 1:10 for lighter soiling.
Bead Juice Exterior Sealant - RRP Inc VAT
500ml - £11.99 inc trigger
1000ml - £18.99 in trigger
5000ml - £44.99
New from Bouncer's is Bead Juice. A Nano Tech Exterior Protection Sealant that can be applied either wet or dry. - Bead Juice is perfectly safe to use on any other coating or existing wax layers. - Can also be used on all exterior inc glass/plastics/alloys etc. Keep your car protected and looking cleaner for longer.
Dry method.
As you would a Quick Detailer, very light mist onto a panel, spread well with soft buffing cloth, turn over cloth and buff again if necessary. Done.
Wet Method.
After your usual wash method i.e rinse after shampoo, spray the product onto the wet panel and rinse off straightaway. - The product is very active, so you can 'level' out the product as well by spreading with a soft MF or sponge applicator, then rinse off - Dry car normally.
Either way, you are looking at 3-4++ months strong protection. Providing strong beading and sheeting, Bead Juice is certainly a product to have, its so easy to use, its almost 'cheating'
To maintain protection on your vehicle. a wax safe / PH7 pure shampoo is recommended. Our Shampoo 'Slick Mick' will compliment this product to keep your car, looking its best.
This product is ready to use and does not require dilution.
Warning:
Bead Juice is an Active spray sealant. On wet application it is imperative to fully rinse and remove product fully via pressure washer and not to allow to linger or allow to dry on paintwork. Use sparingly as over application and or product not fully removed can result in the product leaving a residue behind. - Test on a small area first. If the paint does show areas of residue, this can be removed using a micro polish on affected areas.
Good Luck
J
Handcrafted, Handpoured Premium Car Wax - Made in the UK
Website: propa-protection.com
Facebook: PropaProtection
Twitter: PropaProtection
Instagram: instagram.com/bouncerswax/
The_Bouncer is offline   Reply With Quote
The Following 8 Users Say Thank You to The_Bouncer For This Useful Post:
Alfieharley1 (25-02-2017), BoroDave74 (24-02-2017), magpieV6 (24-02-2017), Rowan83 (28-02-2017), Simz (24-02-2017), Vsti (24-02-2017), wee man (25-02-2017), Wrigit (27-02-2017)
Old 24-02-2017, 01:27 PM   #2
Pittsy
DW Reviewer
Pittsy's Avatar
Awesome
The Following User Says Thank You to Pittsy For This Useful Post:
The_Bouncer (24-02-2017)
Old 24-02-2017, 01:28 PM   #3
DrEskimo
DrEskimo's Avatar
Wow, what a great giveaway! Been meaning to try Done and Dusted for a while now!
How exactly do we enter mate? Just a comment on this thread?
The Following User Says Thank You to DrEskimo For This Useful Post:
Old 24-02-2017, 01:32 PM   #4
JMorty
JMorty's Avatar
Send a message via Skype™ to JMorty
WOW, I'd LOVE this!!
Finger crossed.
Probably end up buying a 5l Bead Juice anyways if I don't win lol
JMorty is offline   Reply With Quote
The Following User Says Thank You to JMorty For This Useful Post:
Old 24-02-2017, 01:34 PM   #5
Luke M
Luke M's Avatar
Very generous of you.
Luke M is offline   Reply With Quote
The Following User Says Thank You to Luke M For This Useful Post:
Old 24-02-2017, 01:35 PM   #6
Typeroz
Amazing offer Bouncer! Someone is going to be very happy, good luck everyone.
Typeroz is offline   Reply With Quote
The Following User Says Thank You to Typeroz For This Useful Post:
Old 24-02-2017, 01:38 PM   #7
Zolasbackheel
Zolasbackheel's Avatar
Great comp Jay. I will definitely be buying the bead juice in a larger size. Have not tried the glass cleaner yet so might have to give that a go as well.
Zolasbackheel is offline   Reply With Quote
Old 24-02-2017, 01:39 PM   #8
Alfieharley1
This is one cracking offer and prize Jay!
Alfieharley1 is offline   Reply With Quote
Old 24-02-2017, 01:40 PM   #9
Spike85
Spike85's Avatar
Awesome Comp
Spike85 is offline   Reply With Quote
Old 24-02-2017, 01:40 PM   #10
Sim
Awesome, great offer.
Thanks for running it.
Sim is offline   Reply With Quote
The Following User Says Thank You to Sim For This Useful Post:
C-Max (24-02-2017)
supersize
