Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bilt Hamber
Old 12-11-2017, 02:09 PM   #1
Tim662
Tim662's Avatar
Atom mac results
Just used atom-mac for the first time on my brakes. I often can't move my car without causing a bit of bother as I'm usually boxed in on the drive. As a result I normally wash the car using ONR and just do the wheels with the hose and bucket. I get very rusty discs after!
Diluted as per instructions to 5% and lightly sprayed onto discs after rinsing but before drying wheels with the sidekick.
A few hours later here are the results...
Perfect.
Highly recommended, especially when you consider that the amount of actual product used per application is absolutely tiny. (And yes, I did remove that tar spec to the left of the first image after )
Tim662 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tim662 For This Useful Post:
MaDMaXX (13-11-2017), Welshquattro1 (12-11-2017)
Old 12-11-2017, 02:55 PM   #2
heavyd
heavyd's Avatar
Atom mac results
Here’s the results off my brake discs today, I don’t share your joy...
heavyd is offline   Reply With Quote
Old 12-11-2017, 03:21 PM   #3
Bilt-Hamber Lab
Bilt Hamber UK
Bilt-Hamber Lab's Avatar
Can you let me know how this was used? 5% solution sprayed onto disc immediately after washing? Then left to dry.
Bilt-Hamber Lab is offline   Reply With Quote
Old 12-11-2017, 03:22 PM   #4
heavyd
heavyd's Avatar
Yep, applied 3 times to make certain. Still looks the same. 50ml in a 1ltr botttle, well mixed.
Old 12-11-2017, 03:26 PM   #5
Bilt-Hamber Lab
Bilt Hamber UK
Was the disc clean and shiny before application? It's not a rust remover, will only prevent corrosion, so if the disc has already flashed it won't reverse it.
Old 12-11-2017, 03:34 PM   #6
heavyd
heavyd's Avatar
Yep, the disc was clean, I’d only been out in the car 20mins before it was washed. I was expecting something better.
Old 12-11-2017, 03:44 PM   #7
Bilt-Hamber Lab
Bilt Hamber UK
Did you apply at the beginning of wash routine or as a very last stage?
Old 12-11-2017, 03:46 PM   #8
heavyd
heavyd's Avatar
I applied after I rinsed the wheels. Then 10mins later, then after the car was rinsed. Then I just applied again 5mins ago
Old 12-11-2017, 03:54 PM   #9
Bilt-Hamber Lab
Bilt Hamber UK
I've PM'd some further info
Old 12-11-2017, 03:56 PM   #10
heavyd
heavyd's Avatar
Ok thanks
