Old 01-10-2012, 12:25 PM   #1
DetailMyCar
DetailMyCar - Focus RS, Caliper refurb, Correction Detail with Ceramishield (20+ hrs)
Here's another DMC write-up, this time a Ford Focus RS (2010) in Performance Blue!
The task ahead was as follows:
  • Caliper & Hub clean up and repaint in Silver (Going for that Factory Fresh look)!
  • Correction detail to remove as much as safely possible in the way of swirls and light scratches
  • Wheels stripped and sealed with FK1000p
  • Fully protected with Concours car care Ceramishield Ultimate Paint Sealant
First of all a couple of pre-inspection shots:
First step was to do the calipers, firstly wheels removed, here's the calipers
Hubs
These were all cleaned up with Meg's APC & Degreaser before being scrubbed with various wire brushes to get into all the intricate areas and get them ready for painting. After this they were blown with the air line to remove any dust and areas where APC / Degreaser were still wet.
Masked up the relevant areas
Removed the retaining clips
First coat of VHT caliper paint
After a couple of coats and dried under halogens they were looking much better once the tape was removed
Wheels ready to be cleaned
Done and sealed with 2 layers of FK1000p!
Wheels refitted and torqued up with a digital torque wrench to 130 (110 for Lockers) as per Focus RS recommended settings
Other side drying
Nice masking line around the adjuster
Bottom one
Rears before
The rears were then cleaned up and painted in the same way, rear wheels then cleaned up and also sealed with FK
Next morning I got the car outside to start on the wash process & decontamination prior to polishing.
After snow foaming and rinsing you could see some great beading on the rims
Car was hand washed with Gliptone Wash N Glo shampoo, then rinsed off and IronX applied all over, not too much in the way of Iron fall out which was good
The car was all clayed and taken inside to be fully dried off and prepared for polishing - few marks visible under lighting
The car was polished with S17+ via a Hex Logic Orange pad and refined with PO85RE on a Blue Hex logic / Green in places
Wing before polishing
After
Door before
50/50 on the door
More 50/50's
Before Vs After
After all polishing was done, the door shuts were cleaned and protected with ZAIO
Full car was then given an IPA wipedown in preparation for Ceramishield
All wiped down
Ceramishield
Tyres dressed with Pinnacle and wheels wiped down with Surf City's hot rod detailer
Ceramishield was applied all over the car, doing 1/3 of a panel at a time so quite a time consuming way of doing it but I wanted to get the best possible result. Each section was buffed off before moving on so afterwards it was looking great
Here are the after shots of the car!
The car was then kept again overnight to allow Ceramishield to fully cure / harden to give best bonding possible.
Here's the car on Sunday morning coming out of the unit
Thanks again for reading, this was a lovely car and I'm really happy with the finish - Looking forward to seeing how he gets on with Ceramishield, but it's getting easier and easier to use each time I apply it but more importantly I'm really happy with the results it generates.
Here's a couple of pics the owner sent me from getting it home to finding it wet this morning!
DetailMyCar is offline   Reply With Quote
The Following 9 Users Say Thank You to DetailMyCar For This Useful Post:
carrera2.05 (03-10-2012), leemckenna (03-10-2012), M.J (06-10-2012), Neil_G (02-10-2012), nick197 (03-10-2012), OILRS (02-10-2012), scotty76 (01-10-2012), streaky (03-10-2012), tonyy (04-10-2012)
Old 01-10-2012, 12:33 PM   #2
JBirchy
JBirchy's Avatar
Looks tremendous, great job on the calipers!
JBirchy is offline   Reply With Quote
The Following User Says Thank You to JBirchy For This Useful Post:
DetailMyCar (01-10-2012)
Old 01-10-2012, 12:54 PM   #3
a1diamond
a1diamond's Avatar
Wow looks fantastic, wheels and the callipers look first class, grand job
a1diamond is offline   Reply With Quote
The Following User Says Thank You to a1diamond For This Useful Post:
Old 01-10-2012, 01:03 PM   #4
RobDom
Looks great, cracking work. Isn't it strange that Ford equipped the Mk1 Focus RS with Brembo brakes but not the Mk2? Cutbacks I guess.
RobDom is offline   Reply With Quote
The Following User Says Thank You to RobDom For This Useful Post:
Old 01-10-2012, 01:08 PM   #5
AaronGTi
AaronGTi's Avatar
Very good Nick looks great.
AaronGTi is offline   Reply With Quote
The Following User Says Thank You to AaronGTi For This Useful Post:
Old 01-10-2012, 02:18 PM   #6
jlw41
jlw41's Avatar
stunning work Nick
jlw41 is offline   Reply With Quote
The Following User Says Thank You to jlw41 For This Useful Post:
Old 01-10-2012, 03:01 PM   #7
MidlandsCarCare
MidlandsCarCare's Avatar
Great work Nick!
MidlandsCarCare is offline   Reply With Quote
The Following User Says Thank You to MidlandsCarCare For This Useful Post:
Old 01-10-2012, 03:10 PM   #8
Juicy Jen
Juicy Jen's Avatar
Nice write up and excellent results...
Juicy Jen is offline   Reply With Quote
The Following User Says Thank You to Juicy Jen For This Useful Post:
Old 01-10-2012, 03:34 PM   #9
dazlee03
dazlee03's Avatar
Why didn't you Ceramishield the alloys? I did it to my girlfriends best thing ive done to that car haha
dazlee03 is offline   Reply With Quote
The Following User Says Thank You to dazlee03 For This Useful Post:
Old 01-10-2012, 03:44 PM   #10
DetailMyCar
I'm not sure I'd have had enough left to do the wheels after all the bits of Piano black had been done etc, plus I had done the wheels the night before after doing calipers so wouldn't have had time to take them all off again :-)
berkshire detailing, detailing newbury, detailinguk, detailmycar, focus rs detail
