Old 16-05-2018, 08:29 PM   #1
Machuga78
Micro Marring Problem
So, I started to remove the swirl marks from the rear quarter of my car over the weekend using CG VSS with an Orange Hex pad and DAS Pro+ DA. After completing rear quarter and following the instructions on the bottle the paintwork was looking a lot glossier. However, having looked at closer in the sun later on it looks like I have left lots of tiny swirls marks which I have since found out is micro marring. I'm just wondering what the next steps are to resolving this and preventing it happening in the future so some advice would be great.
Would refining the paintwork with Menzerna 3800 and a CG green Hex pad help as I have this in the garage?
My car is a VW Mk7 GTD in Tornado Red.
Machuga78 is offline   Reply With Quote
Old 16-05-2018, 08:31 PM   #2
dchapman88
dchapman88's Avatar
Did you have no joy with VSS on a Green pad?
Did you try anything less aggressive than VSS on an orange before you came to that combo?
Old 16-05-2018, 08:39 PM   #3
wish wash
wish wash's Avatar
What were you doing on the residue control side. Were you priming your pads and how often were you cleaning them out/ replacing them
The Following User Says Thank You to wish wash For This Useful Post:
dchapman88 (16-05-2018)
Old 16-05-2018, 08:43 PM   #4
Machuga78
My mistake may have been to watch the CG videos on Youtube and go with their VSS pad combo they were using, in hindsight I probably should have started with the Green Pad. Do you think the green pad and VVS combo would have prevented the micro marring?
I didn't try anything less aggressive unfortunately, I do have Menzerna 2200, 3500 and 3800 in my stock of polishes.
Old 16-05-2018, 08:44 PM   #5
Machuga78
I primed the pad at the start with AG Fast Detailer and used one pad to do one rear quarter panel.
Old 16-05-2018, 08:47 PM   #6
wish wash
wish wash's Avatar
They are created because the heavy cutting pad combined with a cutting compound is often not capable of finishing down perfectly, and therefore leaves behind these very fine scratches which appear as 'tick marks' and are referred to as micro marring.
That's why it's important to do a test spot so know what pad and polish combo will work best
The Following 2 Users Say Thank You to wish wash For This Useful Post:
camerashy (16-05-2018), dchapman88 (16-05-2018)
Old 16-05-2018, 08:47 PM   #7
dchapman88
dchapman88's Avatar
As a general rule you should try the as least aggressive method as possible first
So if you wanted to use VSS then try at white pad, or green first
See how it works for you
I like VSS, I know many don't, but it works
And if VSS on and orange is correcting for you but leaving haze or marring then it may been refining
A finishing Menzerna on a black or white CG should put an end to haze/marring
Altho above it has been commented on pad priming and cleanliness
Both extremely important
Old 16-05-2018, 09:12 PM   #8
Machuga78
Micro Karting Problem
Thanks for the advice, I'll see how I get on with the refining using Menzerna and I'll start with a less aggressive pad with VSS on another 2x2 section starting with white and then moving to block if required.
Old 16-05-2018, 09:23 PM   #9
camerashy
'Detailing Devil'
camerashy's Avatar
Let us know how you go on
camerashy is online now   Reply With Quote
Old 16-05-2018, 11:06 PM   #10
Benfr16
Benfr16's Avatar
It might others if you tell us your car make model and colour and also some pictures so we can see exactly what's up as someone may have had a similar issue and found a resolution!
I've had some issues and got good results with menz 3500 on white hex pad but going lightest and working up is a good shout. ( car black seat Ibiza 2016)
