So I've thoroughly cleaned my glass and applied AW H2Go to all exterior surfaces.
Question is, as I have no running water I clean my car in summer with ONR and BSD a panel at a time.
I'm wondering, will ONR affect the glass coating I applied? Can I use AW Vision without affecting it or I also have AG Fast Glass.
While not the same window sealant, I’ve used RainX for ages. Never made any consideration to what products I use on the treated surface.
Even used Megs Wash+ and AG Glass polish to try and remove it once and couldn’t get it off. So I think you’re probably fine with a good glass cleaner to remove the last smears after an ONR wash.
Although that being said, when ONR is made up to a QD strength, it is advertised as being suitable for glass cleaning.
While not the same window sealant, I've used RainX for ages. Never made any consideration to what products I use on the treated surface.
Even used Megs Wash+ and AG Glass polish to try and remove it once and couldn't get it off. So I think you're probably fine with a good glass cleaner to remove the last smears after an ONR wash.
Thanks for that. I was wondering it glass polish would remove it or reduce it's effectiveness, likewise I wondered if a QD or ONR would place a coating on top and effect it that way.
I doubt if the stuff will be affected but it's worth asking the question as I took a while to get it on there.
So I decided to contact Angel Wax and they say it's fine to do any normal washing, the H2GO will remain in place and would need a good machine polish to remove it.:buffer:
I have used ONR over several different glass coatings and it has not made any difference, just like ONR is not fussy if it is clean a panel with wax or a sealant
using adams glass boost on the front windscreen and qd as a drying aid on the sides and rear
and yeh all mine are coated with carbon collective platinum glass
Related Threads
Detailing World Forum
5.8M posts
94.2K members
Since 2005
