Old 01-08-2017, 07:50 PM   #1
JayMac
Gloss Black B-Pillars
Hi guys,
Wondering if I could get some advice, I have a Volvo V40 which has gloss black b-pillars which are lightly swirled. I have Gtechniq C4 which I want to apply to help protect them, but firstly the swirls need taken care of before applying the coating.
I haven't currently got a DA, but do plan on getting a DAS-6 Pro in the near future, I haven't used a DA before or any other machine polishers for that matter so I'm a total beginner!
So I'm wondering if I should try to sort out the b-pillars myself or is it too risky? I could contact a professional detailer to sort them out for me, which I feel might be the better option?
Any input is much appreciated!
Jason
Old 01-08-2017, 08:13 PM   #2
bense556
bense556's Avatar
I recently did my parents V40, and it was my first time with a DA. I think the most rewarding bit about it was doing the B-Pillars you are talking about. Them being gloss black, it is very satisfying watching the work take place - and the finish is just amazing.
If you are getting a DA soon, get one of the kits that are available with the Hexlogic pads and Megs 105 & 205. I wish I had done this, as I have spent a small fortune getting all different pads/polishes. Then start with the least aggressive combo - 205 & white pad. Change things if needed.
I used Menzerna 400 cut on an orange pad, but that probably say more about my technique than anything else, but it came up a treat and the C5 I put on protects them nicely.
bense556 is offline   Reply With Quote
The Following User Says Thank You to bense556 For This Useful Post:
JayMac (14-08-2017)
Old 01-08-2017, 08:15 PM   #3
scottk7
scottk7's Avatar
I've done it on my old golf with m205 and a polishing pad. Couple passes, take it easy. Tape off rubbers seals
scottk7 is offline   Reply With Quote
The Following User Says Thank You to scottk7 For This Useful Post:
JayMac (14-08-2017)
Old 02-08-2017, 07:33 AM   #4
lawrenceSA
And remember that the paint on these pillars is usually comparatively soft, so make sure to use the least aggressive method.
lawrenceSA is offline   Reply With Quote
The Following User Says Thank You to lawrenceSA For This Useful Post:
JayMac (14-08-2017)
Old 02-08-2017, 09:28 AM   #5
JayMac
Cheers for the input guys, bense that's a good shout about the megs kit, I think I'm going to go down that route!
Old 02-08-2017, 02:08 PM   #6
Sometimes they're painted, sometimes it's just polished acrylic - either way you definitely want to be taking it gently.
JayMac (14-08-2017)
Old 04-08-2017, 02:42 AM   #7
Titanium Htail
Titanium Htail's Avatar
"Slow speed 2, so that a build up of heat and less introduction of marring, Menzerna is more oily giving longer more effective cutting time".
Have a search on whitedetails.co.uk utube Vlog he has this ^^^ specific information, thanks Jim.
John Tht.
The Following User Says Thank You to Titanium Htail For This Useful Post:
JayMac (14-08-2017)
Old 14-08-2017, 11:12 AM   #8
X-Type_Bobstar
X-Type_Bobstar's Avatar
I sorted the black pillars on a Jag XF like mine using a DAS6, 3 inch yellow spot pad and Scholl S3, then refined with CSP No3. You could get away with using just S3 though.
X-Type_Bobstar is offline   Reply With Quote
The Following User Says Thank You to X-Type_Bobstar For This Useful Post:
JayMac (14-08-2017)
Old 14-08-2017, 11:31 AM   #9
You could do it yourself but considering you haven't used a DA let alone a 3" pad then I would either practice first on a small scrap panel or go and see your nearest Detailer or see if a mobile valeter/Detailer can help you out, it wouldn't cost you much but it's an option
JayMac (14-08-2017)
Old 14-08-2017, 11:43 AM   #10
X-Type_Bobstar
Are you in Belfast? I'm near Luton but my brother moved over to Co Down. Could help you out if I am over visiting him next month?
JayMac (14-08-2017)
