Old 15-04-2018, 06:29 PM   #1
Benfr16
Benfr16's Avatar
How to tell if your brushes need replacing
The last time I used my argos DA, it stopped working. In the hour prior to it failing, it would randomly change speeds and wouldn't always start when I switched it on.
Some one suggested that the brushes might need replacing. Is there any tell tale signs when I look at the brushes that would indicate that? Would the description of what happened prior to failure co-incide with a likely brush problem?
Do I need a specific type of brush or are they generally universal?
Thanks.
Old 15-04-2018, 06:48 PM   #2
Benfr16
Benfr16's Avatar
I see they are not universal. Any one who had found some that fit, i'd appreciate a link
Old 15-04-2018, 06:52 PM   #3
fatdazza
https://www.ebay.co.uk/itm/PAIR-Carb...-/112198944429
Might be of use?
Benfr16 (15-04-2018)
Old 15-04-2018, 06:57 PM   #4
Benfr16
Benfr16's Avatar
Yeah cheers. They look like number 50. I guess for £3 might just have to give it a try..
action, brush, dual, polisher, replacement
