Old 10-03-2018, 08:23 PM   #1
DTB
DTB's Avatar
Do you drain your power washer?
Do you drain your power washer between uses (esp in winter), and if so - how?
DTB is offline   Reply With Quote
Old 10-03-2018, 08:28 PM   #2
bigalc
bigalc's Avatar
Just disconnect the hose and switch on using trigger until water stops running.
Just noticed today my K2 is leaking internally.
The Following User Says Thank You to bigalc For This Useful Post:
DTB (11-03-2018)
Old 10-03-2018, 08:32 PM   #3
Not specifically, switch off, our water off, unplug hose connection and unplug the pressure hose and drain water from pressure washer gun and hose and any water that self drains from pressure washer itself - always done this, not had any issues
DTB (11-03-2018)
Old 10-03-2018, 08:38 PM   #4
c87reed
c87reed's Avatar
My Nilfisk P150 is just left to drain once the hose is removed from the inlet. I don't know of a better way as the manual doesn't specify a method. If I needed to store in freezing temps, I would wrap with a blanket or similar to try and protect from the worst of the cold.
The Following User Says Thank You to c87reed For This Useful Post:
DTB (11-03-2018)
Old 10-03-2018, 08:43 PM   #5
OvEr_KiLL
OvEr_KiLL's Avatar
just disconnect water in pipe and turn off machine then pull the trigger to release some water
OvEr_KiLL is online now   Reply With Quote
DTB (11-03-2018)
Old 10-03-2018, 10:07 PM   #6
pxr5
pxr5's Avatar
I do. Disconnect the hose and then turn on the power until the water stops running. In that time I can disconnect the gun and stow away, so about 30 seconds to do. I think I read to do that when I bought my Nilfisk, and it's just a habit I've got into.
pxr5 is online now   Reply With Quote
The Following User Says Thank You to pxr5 For This Useful Post:
DTB (11-03-2018)
Old 10-03-2018, 10:49 PM   #7
DTB
DTB's Avatar
Just as simple as that - good! I was worried that running dry repeatedly might knacker the pump or something.
Old 10-03-2018, 11:13 PM   #8
Sh1ner
Yes. I don't regard any time of year as safe. I remember it freezing in June one year. I was fishing for the week and we were all in sleeping and survival bags.
I disconnect the water supply connector and the lance connector then run the machine for a few seconds. I have found this to be ok for most machines but some water outlets allow water to remain inside so with the portable types I physically pick it up and orientate/rock the machine to remove any water from the outlet and pump whilst it is running.
With my hot washer the pump outlets are horizontal and any water drains out when it is run so I disconnect the hoses and run the machine for 30 seconds until the tank has drained and no more water appears at the outlet.
If I am not using something for a while then I have hoses that loop from outlet to inlet and prime the machine with anti freeze solution and pump it round. Then plug the outlet to the inlet. This seems to keep any valves from corroding and sticking which I have always found to be a problem with Karcher machines and necessitates an unnecessary strip down.
I always try to keep machines inside but sometimes you have to leave one in the van or shed somewhere.
The Following User Says Thank You to Sh1ner For This Useful Post:
DTB (11-03-2018)
Old 11-03-2018, 12:28 AM   #9
Chris.91
Does the machine need to be on? Think my Nilfisk drains with it turned off.
Chris.91 is offline   Reply With Quote
Old 11-03-2018, 12:54 AM   #10
dholdi
dholdi's Avatar
I'm not sure that this will have any effect on the important part - the pump.
Draining the hose, the gun and the supply hose may well be good practice but how can we drain the pump without running it dry and hence probably damaging it as it relies on the water to cool / lubricate internal parts?
I think, and this is my method, to protect the pw it needs to be moved from or protected from an environment that is susceptible to frost
The Following User Says Thank You to dholdi For This Useful Post:
DTB (11-03-2018)
