Old 12-03-2018, 06:55 PM   #1
joeninety
snow foam lance
Hi,i already own an autobrite snow foam lance with karcher fitting ,was wondering if possible to modify to fit kranzle??
joeninety is offline   Reply With Quote
Old 12-03-2018, 07:03 PM   #2
Paul04
Paul04's Avatar
Yip, you just need to purchase a kranzle fitting. Really easy to change over
http://www.polishedbliss.co.uk/acata...arts-cat2.html
Paul04 is offline   Reply With Quote
Old 12-03-2018, 07:12 PM   #3
joeninety
Thanks for the info,great stuff,now where do i find a cheap kranzle LOL??
Old 13-03-2018, 12:47 AM   #4
neilmcl
Only if you have a vice. The Autobrite lances tend to use thread lock on the attachment and can be an absolute bugger to get off.
Old 13-03-2018, 01:23 AM   #5
GleemSpray
GleemSpray's Avatar
Strip it as much as you can, to remove all the plastic, then soak the brass body in very hot / boiling water for a few minutes and it should help dissolve the daft amounts of threadlock that AutoBrite use - that's what I did and it helped a lot
Sent from my P027 using Tapatalk
neilmcl (13-03-2018)
Old 13-03-2018, 08:05 AM   #6
Paul04
Paul04's Avatar
I thought it would just be a thread sealant so would come off quite easy.
Old 17-03-2018, 08:54 AM   #7
joeninety
Do i try and remove the whole bar with karcher connection from the main brass stalk or do i just need to remove the black karcher plastic connection,not sure where im suppose to remove from.
Old 17-03-2018, 11:47 AM   #8
GleemSpray
GleemSpray's Avatar
Im trying to remember how mine was. I think the rear plastic part screws onto the brass tube, the top wheel is just held on by a screw and the front plastic nozzle was held o by a sliding pin (?).
You end up with just the metal parts and those are the ones which are loctited and need big spanners to separate - so thats the bit that needs hot water to loosen the threadlock.
Also make sure you have a roll of plumbers tape to go on the threads for reassembly - much better than threadlock.
