Old 14-07-2017, 11:11 PM   #1
Slammedorion
Slammedorion's Avatar
Nilfisk C120 - Pumping/ Pulsing on standby
I've looked at many C120 pulsing threads... but can't find a definite fix for pulsing on standby
I've checked inlet and outlet seals - all ok
Checked inlet filter ( was clean )
Presume I need to pull the machine apart... although there seems to be no visible leaks
I have read somewhere about a faulty pressure switch could be the culprit
Anyone help?
Slammedorion is offline   Reply With Quote
Old 14-07-2017, 11:22 PM   #2
OvEr_KiLL
OvEr_KiLL's Avatar
o rings if you havnt already.?
Old 14-07-2017, 11:24 PM   #3
justinio
justinio's Avatar
There will be a small leak somewhere. Just a matter of chasing it down.
Sent from my Nexus 9 using Tapatalk
justinio is offline   Reply With Quote
Old 14-07-2017, 11:28 PM   #4
Slammedorion
Inside the machine?
Old 14-07-2017, 11:34 PM   #5
OvEr_KiLL
OvEr_KiLL's Avatar
Originally Posted by Slammedorion View Post
Inside the machine?
no, theres one of the end of the intlet for the hose pipe connector and also one of the bit that clips in the gun
Old 15-07-2017, 09:10 AM   #6
neilmcl
I had the same with mine a couple of months ago, got some o-rings and changed the one on the hose end that connects to the gun as I noticed a few drips at that end. Completely fixed the problem.
Old 15-07-2017, 09:28 AM   #7
Slammedorion
It's not leaking though?
Works fine when I press the trigger...
Just pulses away on standby?
Old 15-07-2017, 09:52 AM   #8
neilmcl
No that you know of. Mine worked perfectly fine too but did exactly the same as yours and pulsed on standby. It started of once in a while then eventually once every 10 secs or so. Seriously, get a replacement o-ring kit and start eliminating potential areas starting with your hose.
The Following User Says Thank You to neilmcl For This Useful Post:
Slammedorion (15-07-2017)
Old 15-07-2017, 09:54 AM   #9
simonvespa
Have a look at this thread and contact Steve at North West Pressure Washers. If you have checked for leaks it could well be the Start / Stop valve.
http://www.detailingworld.co.uk/foru...d.php?t=386104
Simon
simonvespa is offline   Reply With Quote
The Following User Says Thank You to simonvespa For This Useful Post:
Old 15-07-2017, 10:18 AM   #10
Slammedorion
Mines pulsing every 1-2 seconds...
