Old 25-06-2014, 11:22 PM   #11
jamie crookston
jamie crookston's Avatar
The best way I've found to clean the belts, is to pull them out fully and soak them in a bucket of water a washing powder. Worked a treat In my r26.
jamie crookston is offline   Reply With Quote
The Following User Says Thank You to jamie crookston For This Useful Post:
dann2707 (27-06-2014)
Old 25-06-2014, 11:31 PM   #12
jack-c
jack-c's Avatar
Daniels Blue 182.
Nice project. With the belts the above advice is spot on. Just undo the torx bolt at the bottom of the belt and you can then get 90% of the belt out of the car to save getting any water on the interior. close the door and clean it. I also used a nail brush to gently scrub the belts and also using hot water will make the washing powder work better.
This worked perfectly with my 182 belts and you'll be surprised how well they come up. Will make a huge difference.
jack-c is offline   Reply With Quote
The Following User Says Thank You to jack-c For This Useful Post:
Old 26-06-2014, 07:23 AM   #13
Dank84
Regarding the belts I did similar to the above although for the best results:
First wash your panels down (will explain why later)
Next take pull your belts until they reach the end of their travel (and undo the torx bolt at the bottom which holds the belt in place)
Next take as much of the belt out of the car and shut the car door, effectively trapping the belt in the door shut and leaving most of the belt outside the car
Then, with the help of a friend ask them to and tension to the belt so it is flat against the side of the car (preferably the glass so you dont have it resting on the paint! This is why I mentioned to clean your panels too)
Finally with the belt laid flat and your friend holding it in place get a pressure washer and blast the dirt off (make sure you do both sides)
They will literally come up like new.
Dank84 is offline   Reply With Quote
The Following User Says Thank You to Dank84 For This Useful Post:
Old 26-06-2014, 07:25 AM   #14
Dank84
I have got a video and some pictures somewhere. The pressure washer really does help.
Old 26-06-2014, 07:44 AM   #15
shakeyjakey
Also a steam cleaner is worth having! I bought a cheap one a while back and it has been great at cleaning interiors, engine bay etc!!
shakeyjakey is offline   Reply With Quote
The Following User Says Thank You to shakeyjakey For This Useful Post:
Old 26-06-2014, 09:17 AM   #16
SBM
SBM's Avatar
Hi Dan,
Great thread this! Absolutely love the colour of this too! Nice steady progressing project - Excellent work indeed
I have sub'd
Ben
SBM is offline   Reply With Quote
The Following User Says Thank You to SBM For This Useful Post:
Old 27-06-2014, 06:43 PM   #17
dann2707
dann2707's Avatar
Thank you for the tips with the belts, worked an absolute treat as you'll see later in the thread Thanks again
Rinsed the car down initially.
DSCN2128 by dann2707, on Flickr
Then put the belts in washing powder.
DSCN2129 by dann2707, on Flickr
And washed the car with Chem guys glossworks
DSCN2130 by dann2707, on Flickr
DSCN2131 by dann2707, on Flickr
Fitted a new number plate bulb, LED SMD!
DSCN2132 by dann2707, on Flickr
More random pics
Car was clayed with Bilt hamber medium, glazed with Prima amigo and waxed with Collinite #915
DSCN2133 by dann2707, on Flickr
DSCN2134 by dann2707, on Flickr
DSCN2135 by dann2707, on Flickr
DSCN2136 by dann2707, on Flickr
DSCN2137 by dann2707, on Flickr
DSCN2138 by dann2707, on Flickr
DSCN2139 by dann2707, on Flickr
DSCN2140 by dann2707, on Flickr
It then rained today so I took some beading pics
DSCN2142 by dann2707, on Flickr
DSCN2144 by dann2707, on Flickr
DSCN2146 by dann2707, on Flickr
DSCN2147 by dann2707, on Flickr
DSCN2150 by dann2707, on Flickr
Here are the seatbelts, came up so well!!
DSCN2151 by dann2707, on Flickr
DSCN2152 by dann2707, on Flickr
DSCN2153 by dann2707, on Flickr
DSCN2156 by dann2707, on Flickr
DSCN2157 by dann2707, on Flickr
dann2707 is offline   Reply With Quote
The Following 2 Users Say Thank You to dann2707 For This Useful Post:
James_R (27-06-2014), losi_8_boy (27-06-2014)
Old 27-06-2014, 07:39 PM   #18
James_R
James_R's Avatar
Great work Dan, nice car, looks like you have done a brilliant job of smartening up the interior!
Must sort my seat belts out now I've seen this.
I'm inspired
The Following User Says Thank You to James_R For This Useful Post:
dann2707 (28-06-2014)
Old 27-06-2014, 07:41 PM   #19
sprocketser
sprocketser's Avatar
Great looking ride ! Keep it on .
sprocketser is offline   Reply With Quote
The Following User Says Thank You to sprocketser For This Useful Post:
Old 28-06-2014, 10:45 AM   #20
faboka vrs
Send a message via MSN to faboka vrs
Your making me want to clean mine. Especially the belts. Good work
faboka vrs is offline   Reply With Quote
The Following User Says Thank You to faboka vrs For This Useful Post:
