Old 15-04-2016, 03:20 PM   #11
kartman
kartman's Avatar
Send a message via Skype™ to kartman
Originally Posted by kellaway View Post
Finally with the wheel off i'm greeted by this.
IMG_4145.jpg by Daniel Kellaway, on Flickr
Think they are due a replacement!* :x
Originally Posted by Del-GTi View Post
Looking good.
Some great work you're doing there.
Similar rear brake condition to mine, they're just not used enough.
Check out my thread: http://www.detailingworld.co.uk/foru...d.php?t=302691 non-vrs.
Nice work guys. Have a look at this link: http://www.briskoda.net/forums/topic...vrs/?p=2369858...
Had the same calipers on my old Fabia vRS and these little springs are most definitely the answer to keep the handbrake working as it should and not stick on like they normally do
kartman is offline   Reply With Quote
The Following User Says Thank You to kartman For This Useful Post:
kellaway (15-04-2016)
Old 15-04-2016, 03:45 PM   #12
Del-GTi
Del-GTi's Avatar
Hehe, I bought the springs last week. Hopefully get a chance to fit them this weekend.
The Following 2 Users Say Thank You to Del-GTi For This Useful Post:
kartman (15-04-2016), kellaway (15-04-2016)
Old 15-04-2016, 04:36 PM   #13
GrantB5
Them brakes were well over due haha
The Following User Says Thank You to GrantB5 For This Useful Post:
Old 15-04-2016, 04:37 PM   #14
kellaway
You had predicted the future
kellaway is offline   Reply With Quote
The Following User Says Thank You to kellaway For This Useful Post:
Old 15-04-2016, 04:40 PM   #15
kellaway
So next up was to do a full brake fluid change.
IMG_4225.jpg by Daniel Kellaway, on Flickr
Was 4.99 for 1ltrs from ECP or 9.99 for 5ltrs, madness.
The Gunson Bleeder makes this job very easy!
IMG_4206.jpg by Daniel Kellaway, on Flickr
IMG_4205.jpg by Daniel Kellaway, on Flickr
IMG_4204.jpg by Daniel Kellaway, on Flickr
So went round and managed to remove all the nipples with out breaking any! Gave them all a clean up with the wire wheel.
Bled a total of 2ltrs new fluid though the whole system with out any problems.
How ever, when checking over the front brakes.
IMG_4212.jpg by Daniel Kellaway, on Flickr
Both sides lower slider pins where stuck solid. Managed to free the Offside one and discovered the reason!
IMG_4208.jpg by Daniel Kellaway, on Flickr
COOPER SLIP!* :swear:* :swear:* :swear:
The rubber insert on the pin was completely swollen and nackard!
The drivers side i was unable to remove the pin at all probably due to the swollen rubber insert stopping it coming out the carrier, it would spin but not move forwards or backwards!*
After looking at the price of new slider pins (£22)* :finger:*and the hassle of freeing up the other side I've decided to go down the 312mm brake upgrade route.*
The good news is that after changing the rear and the brake fluid i've not got quite a nice pedal feel back, cant wait to get the 312mm on!
So watch this space!
Old 15-04-2016, 04:45 PM   #16
kellaway
So had a day off work today and the Fabia had developed a annoying rattle sound in the rear so i set about to investigate!
First up she goes.
IMG_4226.jpg by Daniel Kellaway, on Flickr
Think i have found the problem!
IMG_4227.jpg by Daniel Kellaway, on Flickr
IMG_4228.jpg by Daniel Kellaway, on Flickr
IMG_4236.jpg by Daniel Kellaway, on Flickr
The spring washers have broken off allowing the exhaust shield to rattle on the exhaust.
So the first job was to consume these.
IMG_4239.jpg by Daniel Kellaway, on Flickr
Then remove the spare wheel as i was going to pop rivet the shield back on.
IMG_4238.jpg by Daniel Kellaway, on Flickr
IMG_4240.jpg by Daniel Kellaway, on Flickr
Consumption of beer becomes clear, perfect repair material.
IMG_4241.jpg by Daniel Kellaway, on Flickr
Left side
IMG_4242.jpg by Daniel Kellaway, on Flickr
Right Side
IMG_4243.jpg by Daniel Kellaway, on Flickr
All fixed, very solid now with 4 x rivets holding it up.
IMG_4245.jpg by Daniel Kellaway, on Flickr
As that was a quick fix i decided since the spare was out would give the holder and the spare wheel a clean up.
IMG_4250.jpg by Daniel Kellaway, on Flickr
IMG_4251.jpg by Daniel Kellaway, on Flickr
IMG_4252.jpg by Daniel Kellaway, on Flickr
IMG_4255.jpg by Daniel Kellaway, on Flickr
IMG_4256.jpg by Daniel Kellaway, on Flickr
Gave the wheel lock a clean up and grease.
IMG_4257.jpg by Daniel Kellaway, on Flickr
IMG_4259.jpg by Daniel Kellaway, on Flickr
IMG_4260.jpg by Daniel Kellaway, on Flickr
Then i went and picked up some goodies for the weekend, here is a sneak peak of things to come
IMG_4262.jpg by Daniel Kellaway, on Flickr
Old 15-04-2016, 04:50 PM   #17
kellaway
312mm Brake Upgrade - Prep
So i won some Audi TT 2004 ATE 312mm Calipers, Carriers, nearly new disc's and pads off Ebay for an absolute steal! The next day i nipped up to Hartlepool to collect them.
They are in very nice condition, but a clean up and some paint is in order.
IMG_4262-2.jpg by Daniel Kellaway, on Flickr
IMG_4263-2.jpg by Daniel Kellaway, on Flickr
IMG_4265-2.jpg by Daniel Kellaway, on Flickr
First off to free the bleed nipples and banjo
IMG_4268-2.jpg by Daniel Kellaway, on Flickr
Then remove the calipers from the sliders
IMG_4270-2.jpg by Daniel Kellaway, on Flickr
IMG_4271-2.jpg by Daniel Kellaway, on Flickr
Pistons checked for free movement! Both fine.
IMG_4275-2.jpg by Daniel Kellaway, on Flickr
Slider before
IMG_4276-2.jpg by Daniel Kellaway, on Flickr
Slider after
IMG_4277-2.jpg by Daniel Kellaway, on Flickr
Tool for the job!
IMG_4281.jpg by Daniel Kellaway, on Flickr
All prepped ready for paint!
IMG_4286.jpg by Daniel Kellaway, on Flickr
IMG_4291.jpg by Daniel Kellaway, on Flickr
IMG_4294.jpg by Daniel Kellaway, on Flickr
Couple of shots with the paint still wet.
IMG_4297.jpg by Daniel Kellaway, on Flickr
IMG_4298.jpg by Daniel Kellaway, on Flickr
After a day or so of drying!
IMG_4318.jpg by Daniel Kellaway, on Flickr
Got a few things left to go before i'm going to install them, need to tap out all the holes to remove the paint from the threads and clean up some of the rubber parts and bleed nipples that
got paint on! The paint was a bit of a nightmare to work with in my cold garage!
Then nip to ECP pick up some new pads then hopefully all going well get them installed!
Old 15-04-2016, 04:55 PM   #18
kellaway
So got the 312MM Brakes on today!
Started out with getting her on axle stands
IMG_4321.jpg by Daniel Kellaway, on Flickr
Before shot!
IMG_4327.jpg by Daniel Kellaway, on Flickr
Wheel off.
IMG_4328.jpg by Daniel Kellaway, on Flickr
Yummmy!
IMG_4329.jpg by Daniel Kellaway, on Flickr
Drivers side
IMG_4333.jpg by Daniel Kellaway, on Flickr
Yet again, dont bother if you dont have an Impact Screwdriver!
IMG_4336.jpg by Daniel Kellaway, on Flickr
Loosen brake hose banjo bolt before removing caliper.
IMG_4341.jpg by Daniel Kellaway, on Flickr
Remove 18mm carrier bolts! Boy they where tight.
IMG_4344.jpg by Daniel Kellaway, on Flickr
Working them back and forward with the impact got them out!
IMG_4345.jpg by Daniel Kellaway, on Flickr
Pry carrier and pads off!
IMG_4347.jpg by Daniel Kellaway, on Flickr
Yum
IMG_4348.jpg by Daniel Kellaway, on Flickr
Place old caliper out of the way for now.
IMG_4349.jpg by Daniel Kellaway, on Flickr
Now, this is where things get interesting, I've had the car just over a month. I purchased it off a dealer who put on a full mot on the car on the day of collection. Now I've never liked how
the brakes felt since day one. Doing the rears and changing the fluid improved the feel of the brakes but they still wern't that great.
So you can imagine how happy i was to see the state of these discs and pads!
IMG_4350.jpg by Daniel Kellaway, on Flickr
IMG_4351.jpg by Daniel Kellaway, on Flickr
IMG_4356.jpg by Daniel Kellaway, on Flickr
IMG_4360.jpg by Daniel Kellaway, on Flickr
Now, im no mot tester but i cant see how these could pass!.
But here is the best part.
IMG_4355.jpg by Daniel Kellaway, on Flickr
The friction material was completely separated from the back on the pad and was just loose inside of the caliper! Im very anoyed with the dealer and shall be paying him a visit Monday Morning.
Old 15-04-2016, 04:59 PM   #19
kellaway
Anyway moving on!
More weight saving occurred.
IMG_4352.jpg by Daniel Kellaway, on Flickr
IMG_4354.jpg by Daniel Kellaway, on Flickr
Nice carrier bolts.
IMG_4366.jpg by Daniel Kellaway, on Flickr
Cleaned up.
IMG_4367.jpg by Daniel Kellaway, on Flickr
Ready to go!
IMG_4375.jpg by Daniel Kellaway, on Flickr
IMG_4371.jpg by Daniel Kellaway, on Flickr
Disc and carrier back on
IMG_4377.jpg by Daniel Kellaway, on Flickr
IMG_4378.jpg by Daniel Kellaway, on Flickr
Brembo, the choice of champions apparently!
IMG_4381.jpg by Daniel Kellaway, on Flickr
I decided to reuse the discs that i got as they turned out to be Brembo, how every the pads where cheap nasty Drytec. So opted for new.
Back together with the sliders greased in the proper grease.
IMG_4383.jpg by Daniel Kellaway, on Flickr
Swapped the hose from the old caliper to the new and proceeded to pressure bleed.
IMG_4397.jpg by Daniel Kellaway, on Flickr
Finished,
IMG_4398.jpg by Daniel Kellaway, on Flickr
IMG_4401.jpg by Daniel Kellaway, on Flickr
Im pleased to say im very chuffed with how they look.
IMG_4407.jpg by Daniel Kellaway, on Flickr
IMG_4411.jpg by Daniel Kellaway, on Flickr
So took her out for a test drive and WOW. I nearly put my self though the windscreen. Amazing pedal feel and lots of bite and no squirming around on breaking anymore!
Now I'm looking forward to Monday morning when i go have a "quiet" word with the dealer!
Old 15-04-2016, 05:03 PM   #20
kellaway
Small update from this week.
IMG_4617.jpg by Daniel Kellaway, on Flickr
New rear wiper, replacement passenger window switch as mine is goosed and some handbrake return springs.
IMG_4618.jpg by Daniel Kellaway, on Flickr
IMG_4620.jpg by Daniel Kellaway, on Flickr
IMG_4622.jpg by Daniel Kellaway, on Flickr
All sorted, very easy job.
IMG_4623.jpg by Daniel Kellaway, on Flickr
Old wiper past its best.
IMG_4625.jpg by Daniel Kellaway, on Flickr
Popped the new one on, again dead easy job.
IMG_4629.jpg by Daniel Kellaway, on Flickr
Springs compressed in vice to make installation easy.
IMG_4631.jpg by Daniel Kellaway, on Flickr
IMG_4632.jpg by Daniel Kellaway, on Flickr
IMG_4633.jpg by Daniel Kellaway, on Flickr
Cut the cable ties and sorted.
IMG_4634.jpg by Daniel Kellaway, on Flickr
IMG_4635.jpg by Daniel Kellaway, on Flickr
