Old 11-08-2017, 04:37 PM   #321
GrantB5
Nice bit of kit
Old 11-08-2017, 10:29 PM   #322
mgpdoc
mgpdoc's Avatar
Originally Posted by Streeto View Post
Nice job on the engine bay.
Must be so nice to live somewhere which is just dusty - as opposed to road salt in winter and all the crap which corrodes things in the engine bay like bolt heads and metal surfaces.
Yeah I totally see what you mean. Even when we have some snow in Greece and roads get salty it is a pain in the b**t to be honest. Dusty, it can be managed
mgpdoc is offline   Reply With Quote
Old 11-08-2017, 11:03 PM   #323
mgpdoc
mgpdoc's Avatar
So, this is the place we will be working on for this post. This, and the EGR system.
Dpf by mgpdoc, on Flickr
Here's an idea of the crap that goes inside your inlet on a diesel car with just 28k miles on the clock. Sad is it not ?
De-Dpf exhaust install by mgpdoc, on Flickr
Block of plate to the rescue
EGT sensors off
Lamda Sensor off
After A LOT of fiddling and swearing, the downpipe came off
Not in piece sadly as for this to happen probably all the subframe would have to come off so ef it.
First test fit
TB block off plate - will change to matching bolts later
Downpipe path
Here is where it got tricky will get to that later
Final dp part which is modified with a v band to match the rest of my 3inch cat(what cat lol)back
This is the part where we had clearance issues. Downpipe touched the steering rack. Ofcourse, once again, bolt on fitment wasnt the case
So out again to modify it
Reshaped it and it was great afterwards
Matching bolts as promised
Sensor on
These however had to be left plugged and tucked in place, cause the car cannot work without them. Even after the ecu remap. Will see if maybe at a later version.
This map sensor of the DPF was removed though
Untitled by mgpdoc, on Flickr
Egr and boost pipe removal by mgpdoc, on Flickr
As was this EGR part from the Exhaust manifold to the EGR
Car was a little rolling-coal happy
But nothing a wash and wax cant fix
Then i decided to remove the complete EGR assembly as it was no longer used, to save weight and clean the engine bay even more
Oil return line has to be removed
And you have to make a U-joint for the water pipes that run to the coolant radiator of the EGR which is also removed. Luckily i had the U-joint from the A4 hehe
Blocked this hole as well
And this is what was removed
Then, we remapped the car, it made another 10hp but we havent finished yet, will get back to you with more results once we fine tune it
Big shoutout to etuners greece, and Stelios Alexandrakis in particular.
More to come
The Following 3 Users Say Thank You to mgpdoc For This Useful Post:
Caledoniandream (11-08-2017), GrantB5 (21-08-2017), Philb1965 (12-08-2017)
Old 12-08-2017, 10:06 PM   #324
mgpdoc
mgpdoc's Avatar
So another task I have been wanting to address, is the tailights after i removed the paing from the hazard and reverse lights.
Instead I sourced some red tint film like i said i would
Made a template of the area i wanted to cover
Came out awesome with the slightest effort
And still is in place perfectly after much washing, dust, and abuse
Stay tuned, more to come
Mike ( @mgpdoc over at instagram )
Old 13-08-2017, 07:43 PM   #325
Alfa male
Alfa male's Avatar
What film did you use ? I did this to my old car but after a while the red tint faded so had to renew it periodically.
Alfa male is offline   Reply With Quote
Old 13-08-2017, 07:51 PM   #326
mgpdoc
mgpdoc's Avatar
I used some film i sourced over at ebay just to try it.
So far zero fading and holds up nicely. Will let you know if this changes overtime.
Old 13-08-2017, 08:59 PM   #327
mgpdoc
mgpdoc's Avatar
So, truth be told i was pushing my luck somewhat
In the past i entered the sea with the Cherokee pretty ofter at this particular spot. However . . .
This is not a Jeep
Got pulled out by a family car, but not without my pride and my car being hurt as well. AC radiator got pushed by the bad Darkside IC installation probably, and also, wheels were scratched from the rocks at the beach.
Had no Ac for the next days, and scratched wheels, oh well
On my way back home, at a highway parking
Got back to Athens, and lost no time
First AC radiator replacement, and new mounting points and brackets for the IC, properly this time, and not like my half-ass job on a bad product
All done and I love how the new BEHR Ac Radiator is silver instead of black
Looks mean
Temporary Audi wheels while mine were sent to be painted
Gave it a proper wash
Do these wheels make it look like a Renault or is it just me
I also ordered this Powerflex mount - Diesel Specific - To reduce engine movement which was getting frustrating especially after the track visit.
It increased vibration, but reduced movement like it should
Powerflex by mgpdoc, on Flickr
Oem
And then wheels were ready
I opted for a change to see how it would look. I normally like to keep my cars in a two tone theme. And this is no exception, it was red and black.
However, i thought I'd give it a go on something rather different.
So. . .
Gunmetal Wheels by mgpdoc, on Flickr
This is what I came up with
First time on the car
Gunmetal by mgpdoc, on Flickr
They sure look bigger
To be honest at first i couldnt get used to it but the more i saw it the more i liked it
Threw on some Rota caps in Gunmetal which I ordered from UK again
And the box as well
Summer by mgpdoc, on Flickr
Car is currently away on vacation mode, seeing some dusty roads and beaches
Mike
The Following 4 Users Say Thank You to mgpdoc For This Useful Post:
BrummyPete (13-08-2017), Gixxer6 (31-08-2017), kartman (15-08-2017), Top Banana (31-08-2017)
Old 31-08-2017, 10:09 AM   #328
fotismt
All that time the car was running with DPF?
Also did you use a fuel additive?
fotismt is online now   Reply With Quote
Old 01-09-2017, 11:48 AM   #329
ghost_walker
ghost_walker's Avatar
letting the side down, your washer under the bottom bolt is off by little bit
ghost_walker is offline   Reply With Quote
Old 05-11-2017, 05:29 PM   #330
mgpdoc
mgpdoc's Avatar
Yes, it was completely stock DPF-wise. No fuel additives, ever.
It is just the angle i promise
