Go Back   Detailing World > Traders > RaceGlaze / Morethanpolish
RaceGlaze / Morethanpolish www.raceglaze.co.uk / www.morethanpolish.com
Race Glaze / Morethanpolish Established in 2003, built on advice. Car Care - Race Glaze, Zymol, Kenotek UK Distributor, Renovo No.1 UK reseller, Hindsight Worldwide Distributor, Blackfire, Gloss-It. Protection - Car covers, Dehumidifiers, AirChambers, CTEK & Accumate battery conditioners, Custom mats. More - Sonax, P21S, Meguiars, DoDo, Gliptone, Kestrel, 3M & Farecla, Door Protector pads, Wind Deflectors, Seat covers- and UK-wide Detailing
Old 26-03-2018, 01:29 PM   #1
RaceGlazer
Approved Trader
RaceGlazer's Avatar
Discount dehumidifiers - advice
Having supplied dehumidifiers for over 10 years, and using 2 myself, a bit of hopefully useful advice for anyone in the market for a discounted dehumidifier, as they are currently being knocked down at various DIY sheds and on-line retailers.
Adsorption Dehumidifiers like the Meaco DD8L/Junior work by rotating a plate of desiccant crystals past a heating element which draws off the moisture.
Refrigerant or Compressor-based machines draw in air to condense on a cold plate where it is drawn off. It sub-zero temperature this plate freezes, rendering these machines totally ineffective in garages etc. It is this kind of machine that is typically sold in DIY stores and is NOT suitable for unheated garages.
Adsorption machines are more effective at low British temperatures in unheated spaces. Our dehumidifers are suitable for other applications like homes, holiday cottages, boats, caravans, cellars, sheds, storage units and garages.
Whilst the higher claimed performance figures for DIY shed machines may seem appealing, they will only draw this volume of water in almost tropical climates - above 25 degrees and very high relative humidity. In practice, the typically 8L/day rated Desiccant machines will pull this at even 5 degrees, massively outperforming even 20L/day compressor machines. This we learned in a practical test in the ballroom of a stately home where the 8L units had to be emptied daily, yet the 20L one only filled its (less than 8L) tank in 3 days.
More info here: http://www.carcovershop.co.uk/dehumi...ar-storage.asp
Mark Wibberley
DW Approved Trader since 2009
www.raceglaze.co.uk
RaceGlazer is offline   Reply With Quote
The Following User Says Thank You to RaceGlazer For This Useful Post:
WHIZZER (26-03-2018)
Old 26-03-2018, 03:25 PM   #2
Rundie
Rundie's Avatar
I got myself a Meaco DD8L last year for my garage/workshop after doing loads of research on them, great bit of kit and with the drain tube you can switch it on and forget it. Another impressive feature is it will switch on automatically every half hour or so to check the humidity level and will turn off if OK so it's not running all the time, only when required.
Rundie is offline   Reply With Quote
