Old 03-07-2017, 02:17 PM   #1181
I'm wondering why people are buying / making these when good LED torches are relatively inexpensive these days?
(Not a dig - genuinely curious!)
Old 03-07-2017, 02:32 PM   #1182
E60525d
Any links?
E60525d is offline   Reply With Quote
Old 03-07-2017, 03:11 PM   #1183
Originally Posted by E60525d View Post
Any links?
Mostly on eBay but also worth a look at the lighting section of Heinnie Haynes.
Old 03-07-2017, 03:51 PM   #1184
E60525d
I have bought one of ebay, fingers crossed.
Old 03-07-2017, 03:52 PM   #1185
euge07
euge07's Avatar
wouldn't know where to start with that selection lol
Old 03-07-2017, 04:20 PM   #1186
From Heinnie I'd be looking at the Nitecore MT1A, or the Fenix E12.
From eBay, this "Vansky" one looks OK.
(My wife got me a Fenix LD41 a few years ago which is a beast of a flash light, but the lower power modes work well for swirl spotting - and taught me that one of the most important / useful features is variable brightness modes).
Old 04-07-2017, 04:09 PM   #1187
Kam09
If anyone wants to sell their home made sungun then give me a shout
Kam09 is offline   Reply With Quote
Old 13-07-2017, 03:48 PM   #1188
valve5425
Here's another one using a second hand, Black & Decker CP-142 drill. £14 off Ebay, (had a smoking motor!!) with two batteries, charger and case. Nice touch is that there's a battery charge check on the drill.
Needed some "Dremelling" to grind a bit off the screw housings at the front of the drill. Also needed to recess where the rim of the bulb sits as well, increasing it from 50mm diameter to 51mm. Without this the casing wouldn't close properly.
I've only got the Decostar 50 watt bulb at the moment which does show small scratches in daylight, but doesn't show the few buffer trails which I know are there. I'll get the Solux bulb ordered from Amazon.com. Only 1-2 months wait, but when it arrives I'll post how it goes.
valve5425 is offline   Reply With Quote
Old 24-11-2017, 11:45 AM   #1189
Bikeracer
Just made one from an old Argos Challenge drill.
No need to buy a bulb holder a couple of 5 amp chocolate block connectors fasten straight onto the bulb pins.
Found the 12v NiCads were shot so ended up wiring it to a discarded 12volt stairlift battery with about three and a half metres of flex.
Just got a standard 12v 35watt bulb at the moment to try it, but wondering if the cost of nearly £20.00 to get the proper bulb worth it ?
Allan
Bikeracer is offline   Reply With Quote
Old 24-11-2017, 02:46 PM   #1190
Croques
2 months wait you think? I've been waiting since 7 September. A message to Amazon asking where it is revealed it is STILL on back order. So good luck!
Edit:
Just had this email from Amazon.com
"Due to a lack of availability, we will not be able to obtain the following item(s) from your order:
"EiKO 35003 SoLux True Daylight Flood 35 Watt MR16 Halogen Lamp, 36 Degree Beam Angle, 12 Volt, 4700 Kelvin"
We've canceled the item(s) and apologize for the inconvenience. We must also apologize for the length of time it has taken us to reach this conclusion."
Croques is offline   Reply With Quote
