Old 07-01-2018, 07:33 PM   #1
stan laurel
stan laurel's Avatar
b.h autofoam
Hi guys and gals hope you're all well.
Tell me, if i as to apply b.h autofoam through a pump sprayer,could i rinse it off with a hose.
Basically because i'm in a terraced house and the car is on the front,so hosepipe comes through the kitchen and lounge,which i can get away with but the wife aint happy at the idea of power cables as well.
Hope someone can help.
Regards.
stan laurel is offline   Reply With Quote
The Following User Says Thank You to stan laurel For This Useful Post:
DLGWRX02 (16-01-2018)
Old 07-01-2018, 07:42 PM   #2
shine247
shine247's Avatar
For sure, will be better than no pre wash. Use warm water in the sprayer, about 50c.
The Following User Says Thank You to shine247 For This Useful Post:
stan laurel (07-01-2018)
Old 07-01-2018, 09:04 PM   #3
My mum does exactly this for her car (she doesn't have a pressure washer). It's not quite as effective but still good, as mentioned use "tap hot" water in your pressure sprayer.
stan laurel (08-01-2018)
Old 13-01-2018, 09:18 PM   #4
maclof
Definitely the key point here is to use warm water from the tap, will help shift some of the dirt as you're not going to use a pressure washer.
maclof is offline   Reply With Quote
The Following User Says Thank You to maclof For This Useful Post:
stan laurel (14-01-2018)
Old 13-01-2018, 10:18 PM   #5
Philb1965
Used it the other day for the first time with a pump sprayer and couldn't believe how much crud it got rid of.
Philb1965 is offline   Reply With Quote
The Following User Says Thank You to Philb1965 For This Useful Post:
Old 16-01-2018, 11:17 PM   #6
Subc
Normal hose will remove winter crud after applying BH Auto Foam, as for warm water I make up 5L solution in the sprayer and use it a few times over weeks with great results every time. Defo the best out their by a margin. :-)
Subc is offline   Reply With Quote
The Following User Says Thank You to Subc For This Useful Post:
stan laurel (18-01-2018)
Old 17-01-2018, 12:34 AM   #7
PWOOD
PWOOD's Avatar
Thumbs up
What they all said
PWOOD is offline   Reply With Quote
The Following User Says Thank You to PWOOD For This Useful Post:
Old 17-01-2018, 12:38 AM   #8
PWOOD
PWOOD's Avatar
Thumbs up
That will work pretty well.
Old 17-01-2018, 01:02 AM   #9
Brian1612
Brian1612's Avatar
Nails been hit on the head pretty well already. Give the car a rinse with the hose to remove any lose stuff. Mix up some autofoam at 4% with water water in the tap and apply. Allow it to dwell 2 minutes or so then rinse. Should get decent results mate.
