Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bilt Hamber
Bilt Hamber Bilt-Hamber Laboratories has always used research, innovative chemistry and thorough testing as the way to produce better performing products. Every product released for sale has been extensively compared to and tested for superiority against market leading and specialist competitive formulations. From our clay bars to cavity waxes, etch primers to carnauba waxes and shampoos to rust removers, each Bilt-Hamber formulation has been made from conception to production with the same care.
Old 13-04-2018, 09:45 AM   #1
Neil_S
Retired Mod
Neil_S's Avatar
Epoxy mastic over Electrox
The "How to Use" section states
Over coating can be carried out once film is hard dried – but high solvency top coats should be applied after 24 hrs
Then the PDF says
Over coating can be carried out once film is hard dried as described above – but high solvency top coats should only be
applied after 96 hrs
I'm guessing a formula change may have occurred.
For Epoxy Mastic over Electrox, do I need to wait, 3 hours, 24 hours or 96 hours?
Want to understand Zaino?
Neil_S is offline   Reply With Quote
Old 15-04-2018, 12:47 AM   #2
VeiRoN
VeiRoN's Avatar
I.would wait 4 days so that the film has fully dried,granted you can keep temperatures around 15C and not too much humidity.
VeiRoN is offline   Reply With Quote
