Old 09-11-2018, 03:30 PM   #311
tomstephens89
Picked me up a Kranzle M2000 short gun today with 20M of hose from Elite Car Care.
I use TEMA quick connect fittings between gun and the lance so also ordered some more of them for the gun>hose>machine connections as well.
tomstephens89 is offline   Reply With Quote
Old 18-11-2018, 11:39 PM   #312
Abxul
Itemisation/ price
Originally Posted by markcaughey View Post
New Lance and hose turned up today from Q Washers
I quickly put together my outdoor setup now that we are out of the winter and dont need to worry about freezing temps. This cupboard is a pretty good place for the PW as its attached to the house and so long as the door is shut nothing freezes in here, even at -6 ( tested this through the winter )
I just put together a make shift hose reel so will see how that works out and will likely replace it at some point with a proper hose reel
Not the cleanest of set ups with all the other clutter in there but it will do the job and will be much better than setting up the washer from scratch and putting it all away for every wash.
Hi Mark
Wondering what exactly you got charged/ paid for please? Alongside tips for getting through to Damian in endeavour to place the same order
Many thanks
Abxul is offline   Reply With Quote
Old 20-11-2018, 10:57 AM   #313
Slick 77
Slick 77's Avatar
hi all, need some help as I have upgraded from a K2 to K5 Karcher pressure washer
I recently bought an extension hose for my K2 so would like to keep that, it looks like all I need is some adapters so that I can use it with my K5?
I connect this https://www.ebay.co.uk/itm/1-4-BSP-M...UbYg:rk:1:pf:0 to my pressure washer to allow for the K2 extension hose (M22 fitting)
This on the other end of the extension hose to connect to new karcher quick release hose
https://www.ebay.co.uk/itm/Pressure-...OVO:rk:18:pf:0
is this the same as these sets?
https://www.ebay.co.uk/itm/Pressure-...EVuY:rk:8:pf:0
https://www.ebay.co.uk/itm/1-4-Femal...Gf8U:rk:2:pf:0
many thanks
Slick 77 is offline   Reply With Quote
Old 21-11-2018, 10:15 AM   #314
bradley221985
What size orifice will I need on the quick release nozzles? I have a Kranzle 1152. I have seen different answers on here ranging from 035 to 045
bradley221985 is offline   Reply With Quote
Old 22-11-2018, 06:06 PM   #315
Croques
1152 uses a Kranzle unique 042 nozzle size. 040 will give slightly higher output pressure and 045 slightly less. I use 045 on all my kit.
Old 22-11-2018, 06:55 PM   #316
bradley221985
On eBay I have also noticed with some as well as choosing the 040 or 045 sizes you can also choose different gpm's. Which gpm do you use with your 045?
Old 22-11-2018, 09:29 PM   #317
Croques
I think you need to read up on the theory underpinning pressure washers. The flow is set by the pump - the volume swept by the pistons. For the Kranzle 1152 that is 10 litres per minute.
diy, pressure, upgrade, washer
