Old 01-05-2016, 09:27 PM   #501
DTYME83
Nice
DTYME83 is offline   Reply With Quote
The Following User Says Thank You to DTYME83 For This Useful Post:
mgpdoc (08-05-2016)
Old 08-05-2016, 01:14 PM   #502
mgpdoc
mgpdoc's Avatar
almost 100k on the clock
So did some work, mostly maintenance, that was postponed for some time now, although i did have the parts needed, lol. It is just that I want to do some things by myself I guess.
Makes my OCD feel happy.
Temporary wheels are not so bad after all
So, first I bought this
Passenger door would lock and unlock depending on weather, luck, and temper I guess, so I went for original and new parts, no china parts, not used parts, and once I show you what it takes to replace it, I am sure you would do the same, LoL
Grab a coffee, and go to the passenger side if you are about to do this.
Remove the plastic cover to give access to side bolts
Behind the oem round sticker is this bolt that you need to undo, not fully
In order to remove this (while pulling the door handle as you unbolt)
Then you remove the hinge and you can also remove the door handle
You also unbolt the T20 torx screw behind the door handle.
Then, time to take the door cover off
Remove all the bolts around the door card, just note which one goes where
also these
Remove the door card (easier with two people, I did it on my own)
And you are left with this
Like a Car X Ray, LoL
Then, you remove this little o-ring and out comes the weird metal assembly
You then have to remove this plastic white cover to gain access to the lock
So dirty
Gave it a quick clean
Old and dirty lock
Take these two bolts out, to remove the lock assembly (attention these are not torx screws)
Remove it from the metal tab of the door, and then disconnect the hinge
Side by side
This is the part you have to transfer from the old one to the new one
Dirty doors make me sad
Better
Installed
Dont forget the hinge
And also the cover
Putting the door card back on your own is a bit tricky but it can be done
Gave the plastic cover some love
And it was ready to close everything again
Happy to report, everything works great
The time to install the new passenger side wheel arch as the old one was damaged
New hardware
All done
Lower side
I then washed the car, happy to see it still keeps some nice beading after all this time
Then it was time for some interior work - yes it is dirty i know
Tired passenger parts
New parts
Happy with that
Removed the Thule bars for now, as I am mostly travelling with the AUD1ESEL now, i think it still looks sharp after all these years
Cheers more to come
Mike
mgpdoc is offline   Reply With Quote
The Following 6 Users Say Thank You to mgpdoc For This Useful Post:
chongo (08-05-2016), FranJR (09-05-2016), GrantB5 (21-05-2016), JB052 (10-05-2016), kartman (09-05-2016), Tuddie (08-05-2016)
Old 08-05-2016, 01:38 PM   #503
Tuddie
Tuddie's Avatar
Send a message via MSN to Tuddie
Fantastic looking car!
Tuddie is offline   Reply With Quote
The Following User Says Thank You to Tuddie For This Useful Post:
mgpdoc (08-05-2016)
Old 08-05-2016, 01:54 PM   #504
Streeto
Streeto's Avatar
Some of the pictures don't match the descriptions I'm afraid my friend.
Streeto is offline   Reply With Quote
Old 08-05-2016, 02:27 PM   #505
Lovely car, them seats look stunning.
mgpdoc (08-05-2016)
Old 09-05-2016, 11:16 AM   #506
Jonny_R
Jonny_R's Avatar
top work and attention to detail as always buddy
Jonny_R is offline   Reply With Quote
The Following User Says Thank You to Jonny_R For This Useful Post:
mgpdoc (10-05-2016)
Old 09-05-2016, 04:34 PM   #507
FranJR
excellent work doc!
FranJR is offline   Reply With Quote
The Following User Says Thank You to FranJR For This Useful Post:
mgpdoc (10-05-2016)
Old 09-05-2016, 04:46 PM   #508
Streeto
Streeto's Avatar
Much better
The Following User Says Thank You to Streeto For This Useful Post:
mgpdoc (10-05-2016)
Old 09-05-2016, 06:39 PM   #509
bazz
bazz's Avatar
Send a message via MSN to bazz
great job
bazz is offline   Reply With Quote
The Following User Says Thank You to bazz For This Useful Post:
mgpdoc (10-05-2016)
Old 10-05-2016, 12:07 AM   #510
mgpdoc
mgpdoc's Avatar
Originally Posted by Streeto View Post
Much better
I didnt change anything though. Must have been a photobucket thing I guess
