A common sight on everyone's bonnet is stone chips unless you've just had it re-sprayed but even then they are still inevitable!
So after spotting a few on mine I thought I would have a go at repairing them after reading a couple of repair guides. Firstly I got hold of some touch-up paint from Paints4U you can alternatively just buy a touch-up stick from the stealers but for the same price, I got a 100ml tin of paint and 30ml clear lacquer which was a perfect colour match too it also came with a fine artists brush.
I also got some IsoPropyl alcohol to clean out all the dirt, crap, polish & wax from the stone chips, once this was done i went round filling the chips with paint and making sure the paint filled the chip and not the area around it as this can easily be done if you use a brush that's too thick you need to fill the chip so that the paint is raised over the area of the chip.
once left to dry the bonnet looked like this with blobs of paint
the wet & dry paper I used was Meguiars unigrit 2500
The next job was to wet sand the blobs of paint down to the same level as the existing paint and the best way I found to do this and keep the repairs to the local area was to wrap a small bit of sandpaper around the end of a flat piece of plastic (aka a bicycle inner tube remover!) or a pencil and gently rub down the raised paint and then level it out with the rest of the surface.
I used plenty of water with fairy liquid which foamed up nicely and acted as a good lubricant and also soaked the sandpaper in some fairy liquid before hand.
some nice sanding marks afterwards!
these were easily removed using my porter cable polisher with a "4 lake & country orange light cut pad & Menzerna Intensive polish, the whole bonnet was then followed up with Menzerna Final Finish Polish (P085RD) with a "6 Sonus SFX blue finishing pad and 2 coats of Collinite 476s wax.
if you don't have a porter cable you can easily remove the sanding scratches by hand using 3M Perfect-It III fine cut compound
I'm gonna do this in the next couple of days, so i just need clarification on what grade wet and dry to use, is it soley 2500 or do i use 3000 and 2500, cheers.
Actually come to think of it i have another question, i bought a chip repair paint from my local Honda group, when i open the bottle the paint looks a hell of a lot darker than my car, they asure me it's the correct one but i'm not so sure, any ideas.
the paint will look a lot darker when wet but once its set and dry it will be fine and should blend into the rest of the bodywork with no problems as its just a very small amount of paint you are using as supposed to trying to repair or re-spray a bigger section
i bought a clio 172 last week, its had lots of stone chips on the front bumper, paint has been added to it. But it seems to have not filled the chips propper
I followed this guide and got some amazing results (if I do say so myself)
Yes add more paint, mine took a couple of goes to fill the chips so they were just proud for the surface, but I felt this was a better approach than having a massive blob that needed a lot of sanding. I left it just over an hour between coats and 24 hours until the final wet sanding.
Did you fill in the chips or were the chips filled in when you got the car? The only reason I ask is that if it is old paint you might want to give it a little rub with some unigrit 2500 so the new paint keys in properly and won’t come away when you wet sand it later.
Ive just got a 100mm tin of Star silver metalic from Paints4U, for a Vaux Astra. On the bonnet and top of the boot lid, the colour shade match is near perfect. However, doing a scratch on the vertical section of the boot and door skins, the paint had dried a few shades darker. Any ideas how to get the same shade as a horizontal pannel ( without tipping the car on its side :lol: ) I guess it is the way the flakes are alligned in the paint, and suspect there is nothing that can be done to prevent it
There are much scarier images, i.e. the look of your car after a full machine sanding! :doublesho
I re-assure you that the 2000 - 300 grit amrks wil leasily be removed with your G220 and Menzerna polishes if you use 2000 grit i find sanding with 3000 grit afterwards makes polishing the sanding amrks out easier, just dont rub too hard!
you can use the same process for bumpers but i find it can be tricky if the scuffs are on a curved area the hardest part is laying the paint down evenly as with a chip you just need to fill it but scuffs can be a bit more tricky and would prob be easier to correct with spraying unless they are slighly deep in which case you can fill them
I was inspired by this guide, the family has 3 black vauxhalls so Ive invested in some paint and a seperate clear coat. I've got a few sheets of 2000, 2500 and 3000 grit paper, and today picked up a G220, 2 pads and some #83, thats all the shop had left. My sister has a few key marks in her's from 2 weeks after she bought it. Anyway I've filled all the scratches and chips with paint just as in the guide but not applied any clear coat.
Do I wet sand them flat then clear coat and sand again or sand flat clear coat and then the DA? I hope to have a go at the weekend so any help could be useful, she has decided to buy another car.
Can this method be used for keying damage as some scumbag has keyed my car ? or am i looking at getting the panel resprayed ? the damaged area is 7 inches long.
I had a go today, a few stone chips and a few nice key marks like yours well these broke through to the base layer. I painted them a few weeks ago with thin layers and built them up to just above the surface, wet sended them today with 2500 grit then 3000 grit to flatten them but I either painted them baddly or took too much away and the edges of the paint in some parts have the white primer/undercoat showing through but some parts are spot on. I then went to it with my new G220 and some #83 and it removed the sanding marks with out problem just a few passes I will need to paint again I think sand then polish and then put a layer of clear coat on to make the area shine as at the moment the filled scratches just look matt and not shiney like the rest of the paint then another polish proberbly with megs #80.
fantastic guide, going to give this a shot sometime. Near the intake vent on my rear arch area on my Porsche, I have noticed it is hammered with stone chips and filling them with paint is difficult due to sheer number of them in that small area. The picutre doesn't really show them that badly due to the flash, but it looks horrendous in person. Any ideas on how to tacke such an area?
I think the langka repair system uses a squeegee system to spread paint over an area with large chips and fil lthem all then remove excess paint from around the area.
and yes you can use 4000 grit wet might take you a bit longer to sand down though i've found I have to resort to 1200 grit sometimes to level down the paint/lacquer to the surrounding area
My ibiza is the same, black paint, 9 years old and a GTi that the previous owner used for going down the motorway to work with, which is the worst for picking up stone chips.
When i decide to finally order my megs PC G220 i'll definately be giving this ago.
Thanks, Dave
Related Threads
Detailing World Forum
5.8M posts
94.2K members
Since 2005
