Old 10-01-2017, 10:49 AM   #31
Rían P
Rían P's Avatar
Lovely motor sir!
Cream leather seats are hard beat!
Looking forward to the next update. Always like seeing engine maintenance coming first.
Good man,
Rían P
Rían P is offline   Reply With Quote
The Following User Says Thank You to Rían P For This Useful Post:
GrantB5 (10-01-2017)
Old 10-01-2017, 11:00 AM   #32
GrantB5
Originally Posted by JMorty View Post
It certainly sounds a bit like a vacuum leak...
Exactly what I thought. I will get this hose changed over and then check the PCV next as been suggested.
My spark plugs and vacuum pipe turned up today
Old 10-01-2017, 09:19 PM   #33
Disco Smudge
Do the revs blip at all, without your input? Another thing is there is a one way valve in one of the vacuum hoses. Try taking the oil cap off with the engine running if there is suction that valve can be the culprit
Disco Smudge is offline   Reply With Quote
The Following User Says Thank You to Disco Smudge For This Useful Post:
GrantB5 (11-01-2017)
Old 11-01-2017, 10:17 AM   #34
Barchettaman
Barchettaman's Avatar
Originally Posted by GrantB5 View Post
Yeah go ahead. I'm still behind with mine, get my hydraulic brakes end of this month I think. Want it over and done with now ha
Apologies for the thread drift:
Vortrieb CX frame, 62cm, Kinesis fork
Ritchey WCS headset
Syntace bar & stem
FSA PowerDrive crankset 46/36
The rest of the drivetrain is 10-speed 105
Oval Concepts wheelset with Schwalbevstudded snow tyres
Currently set up with a slightly higher bar/stem and platform pedals for safer snow commuting.
Barchettaman is offline   Reply With Quote
Old 11-01-2017, 10:28 AM   #35
GrantB5
On idle the revs are not perfect especially on cold start.
I do have some one way valves in the system. I want to remove a load of the system but I'm speaking to a few people to try and get a guide for the AGU.
Where I don't have SAI I don't have to remove a EVAP system I'm assuming but all the videos I have seen have that, although some of the vacuum system is similar.
Old 11-01-2017, 10:30 AM   #36
GrantB5
Originally Posted by Barchettaman View Post
Apologies for the thread drift and gigantic photo:
Ritchey WCS headset
Syntace bar & stem
Looking good, hows it handling the snow? We have no snow here but I have read of a few people hitting ice here in London. Seen someone with a broken hip. Quite glad I'm in the car on the way to work rather than bike for now
I think I am going to stick with platform pedals, I don't like the idea of clip in, maybe because I have never tried before but hey.
Old 11-01-2017, 10:58 AM   #37
Smanderson117
Yeah a lot of people do the catch can mod. My y piece pipe split at one point and spewed oily vapours all over my engine bay common problem I hear, they go brittle with the heat.
Do the N249 bypass mate you won't be disappointed! good to hear you don't have the SAI system, its a fairly heavy piece of kit the pump itself to be honest.
DV is on the list for sure. I will be doing dog bone mount bushes and the actual bush under the gear gaitor together.
Once I have the TIP and a new MAF I will then start looking at polybushing the car.
Car will be having new suspension at some point in the near future for sure.
I bought an SAI delete plate but it turns out the AGU doesn't have that system so I got a refund. I want to get rid of a load of vacuum pipes, I have ordered some 4mm vacuum pipe now but also want to look at the PCV system too.
Yeah stock suspension isn't great by any means.
Smanderson117 is offline   Reply With Quote
The Following User Says Thank You to Smanderson117 For This Useful Post:
Old 11-01-2017, 02:15 PM   #38
Barchettaman
At the risk of tempting fate it´s absolutely feckin´awesome in the snow. The tyres are 622/42 with loads of studs and grip like crazy. The studs are off the centre line so if the wheel starts to ´go´ sideways the studs dig in and the tyre grips again.
Having said that it´s all thawed now so the bike´ll be going back in the shed til the next snowfall.
Bearing in mind I had the wheelset sitting around spare, I have about €240 in the bike as it stands, so it´s worked out pretty well really.
The Following User Says Thank You to Barchettaman For This Useful Post:
percymon (11-01-2017)
Old 11-01-2017, 03:47 PM   #39
GrantB5
Yeah heard only good things about the n249 bypass but I have seen a couple ways of it being done. One being bypassed kind of and one being completely removed and using a resistor which I am in favour of!
Will get a resistor ordered now for starters and go from there and do the N249 today.
Old 11-01-2017, 03:48 PM   #40
GrantB5
We are due snow in London tomorrow, supposedly, but who knows.
Wish I only had 240 euros in my bike, by the time I'm done maybe £700? Maybe more
