Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Zaino
Old 21-09-2015, 10:11 AM   #1
mikey_abz
mikey_abz's Avatar
Question Zaino Sequencing - Alfa Giulietta QV
Folks,
I'm in the process of buying a new Alfa Romeo Giulietta Quadrifoglio Verde in Ghiaccio White.
With the car being Brand new I want to spend a full day or two cleaning it properly (I will take before and afters once done).
Prior to the car delivery I have bought Zaino Products: ZAIO, Z2, Z6 & Z8 for the body panels.
(I will use FK1000P for the Black 5 Hole Alloys and FK108AS for Tires).
With those Zaino products I was thinking of following this sequence (once the car has been cleaned/dried properly): 1 coat ZAIO, 3 coats Z2, 1 Coat of Z6
then 2 Coats of Z8?
Would you do it this way? or have I missed something?
Thanks,
Mike
mikey_abz is offline   Reply With Quote
Old 21-09-2015, 01:59 PM   #2
spookyZeus
spookyZeus's Avatar
What are the time scales for the multiple coats of Z2?
If doing multiple coats of Z2 within 24hrs Zaino recommend using the ZFX kit, this aids/accelerates the cure time and allows multiple coats. Without it I think they suggest 12/24hr cure time.
After using ZAIO ... Using the Z2 with ZFX put on a coat, wait 20mins then buff off, then put a coat of Z6 on and buff off. Repeat this a total of 3 time then finish with an extra coat of Z8
spookyZeus is offline   Reply With Quote
Old 21-09-2015, 02:56 PM   #3
mikey_abz
mikey_abz's Avatar
I have the ZFX but I have never used it before.
I was going to wait a few hours between coats.
Old 21-09-2015, 03:39 PM   #4
If you have ZFX then use it, just put in 2 oz or half a tube full of Z2 apply 5 drops of ZFX (blue) mixture into the tube of Z2 shake well for 90sec then you can apply a thin coat to each panel, but to get the best out of Zaino your paint has to be free of all contamination and swirls.
Old 22-09-2015, 01:57 PM   #5
spookyZeus
spookyZeus's Avatar
Yes as above, the ZFX is very easy to use.
The Following User Says Thank You to spookyZeus For This Useful Post:
David Proctor (06-10-2015)
alfa romeo, ghiaccio, quadrifoglio, white, zaino
