Old 03-06-2018, 05:56 PM   #1
R32 mad
Which High Pressure Hose For Nilfisk D140 / E145??
Hi all, I'm about to get a Nilfisk pressure washer, either D140 or E145.
I'm looking to get a 25 meter hose, but have no idea what type connections they are.
I see on ebay qwashers do different variants for the C range and also some for the E130 or E140.
Can someone tell me if any of these will fit the models in question. these two have different connections but how would you know if some of them fit various other models?
https://www.ebay.co.uk/itm/Nilfisk-A...19.m1438.l2649
https://www.ebay.co.uk/itm/25-Metre-...19.m1438.l2649
R32 mad is offline   Reply With Quote
Old 03-06-2018, 08:34 PM   #2
stealthwolf
stealthwolf's Avatar
I used to have a C120 and bought a 15m hose off qwasher. When it broke, I replaced the machine with the E140.3. An aftermarket hose will not fit without an adaptor. There was one available for the E140.2 which meant you could use a qwasher hose but Nilfisk changed things. I bought an adaptor off northwestpressurewashers which should fit but doesn't. Turns out it fits M22 and Nilfisk use 1/2 BSP.
Old 03-06-2018, 09:00 PM   #3
R32 mad
I'm a beginner when it comes to pressure washers. So what adapter would I need to fit an E140 pressure hose to a E145?
Old 04-06-2018, 09:18 AM   #4
stealthwolf
Pass. Hopefully someone else will come up with an answer because it'd solve my problem too! At the moment, I have a 15m long qwasher hose that I can't use and a 9m hose that came with my E140.3 that's short and crap.
Old 04-06-2018, 09:46 AM   #5
R32 mad
So the long and short of it is, if you need a machine to attach an extension hose that's more than 20 meters you're limited to the C range of Nilfisk pressure washers without a hose reel?
Old 04-06-2018, 10:36 AM   #6
stealthwolf
Being completely frank, if I knew Nilfisk had changed the design of the E140 (from .2 to .3 version), I would have just bought another C120 to replace the first one.
Wait to see if others are able to offer any help.
Old 04-06-2018, 10:58 AM   #7
spyk3d
Just a thought but could you not get something like this or this to join the M22 and 1/2 BSP together?
spyk3d is offline   Reply With Quote
Old 04-06-2018, 11:27 AM   #8
R32 mad
Would this be the part?
https://www.northwestpowerwashers.co...roductid=19389
Old 04-06-2018, 11:47 AM   #9
spyk3d
No it woulds be thisone and then you would buy one of the other connectors I've just previously posted to connect your hose to it.
Old 04-06-2018, 12:18 PM   #10
stealthwolf
That's similar to the one Dooka bought (but that was straight). He did a guide where he showed how to fit an adaptor and it all worked fine. As I stated, that's for the E140.2
Yup that's the one I have and same problem. I did order a male 1/2 BSP to M22 female adaptor off ebay and it wouldn't fit the M22 side.
>here< I think the "nose" was too long and intefered with the fitment.
