Old 07-06-2018, 06:23 PM   #1
Tifosi
Dodo Leather Kit
I have the leather cleaner and sealant kit and used it about 6 weeks again, to good effect. How often are we thinking the leather seats and trim should be cleaned and re-sealed, after relatively light useage?
I did see a marked improvement after re-treating so I am thinking monthly(ish)?
Tifosi is offline   Reply With Quote
Old 11-06-2018, 07:47 PM   #2
Tifosi
212 views and no opinions? A first!
Old 11-06-2018, 08:00 PM   #3
dchapman88
dchapman88's Avatar
Is there no kind of directions from the manufacturer about re-aplication?
I generally clean my leather monthly and it barely leaves any marks on the white MF towel I use to clean with
So if you have light to moderate use and wear on them id say that once a month for sealant seems excessive....
Old 11-06-2018, 08:10 PM   #4
Tifosi
No. Not that I can find, hence asking. Added to that, user experience invariably yields a better guideline. So, from what you say, just apply the cleaner monthly, over the last coat of sealant?
Old 11-06-2018, 08:17 PM   #5
Peter77
Peter77's Avatar
I use the dodo combo every couple of months. In between I find a damp cloth just wiped over is enough
The Following User Says Thank You to Peter77 For This Useful Post:
Tifosi (11-06-2018)
Old 11-06-2018, 08:19 PM   #6
dchapman88
dchapman88's Avatar
If your not seeing any deterioration in the properties on the sealant then I would just clean when required and then when you start to see the sealant failing then reapply
Tifosi (11-06-2018)
Old 11-06-2018, 08:41 PM   #7
Tifosi
Thanks for that, Peter.
Old 22-06-2018, 05:23 PM   #8
Furniture Clinic
Dw Sponsor
Furniture Clinic's Avatar
HI There
When we are recommended a care regime for leather, whether it be car interiors or furniture, we would generally advise that every 3-6 months, you should clean the leather with a product like our Leather Ultra Clean. The Ultra Clean is a general cleaner which will remove any dirt and grime from the leather’s surface. Although it is a strong cleaner, it is safe to use even on all leather and vinyl. You may find that you also benefit from using the Tampico Brush, as this will help to remove the dirt/grime which is trapped within the grain.
When the leather is dry, apply some Leather Protection Cream to add an additional protective layer to the leather to help protect against spillages and make the leather easier to clean in future. It even contains UV inhibitors so is ideal for car interiors.
Leather Care Kit: http://www.furnitureclinic.co.uk/Leather_Care_Kit.htm
Tampico Brush: http://www.furnitureclinic.co.uk/Tampico_Brush.php
Sponge & Cloth Bundle: http://www.furnitureclinic.co.uk/Sponges_Cloths.php
Leather Care & Repair Specialists
Furniture Clinic is offline   Reply With Quote
