Old 12-07-2018, 01:32 PM   #11
fatdazza
Originally Posted by keithjmason View Post
Have started to play around with RO
Just a quick question. Does the incoming water pressure impact the TDS of the water that comes out the membrane ?
From my understanding, the water pressure would affect flow rate and % of water ‘wasted’ only.
My water pressure is not that high, but within the spec of what the membrane needs. I’ve run it at a few different pressures (night seems to have higher pressure than daytime) and the TDS out the membrane remains pretty constant.
The reason I ask is that TDS out the membrane is 22 (input water is 342) and I was expecting it to be lower - possibly as issue somewhere, or is this actually expected ?
At this TDS, I would be replacing the resin in the little final stage filter very very often.
Any advice I would be very grateful.
Also I went for the 75 GPD membrane. Water pressure has been between 3 and 4 bar during testing. And always water out the membrane is 22 TDS
Membrane quotes 97.5% - and so I would think the water out should be closer to 9 TDS
Maybe I’ve got something wrong in my understanding though.
Keith
22TDS from the membrane is pretty good. Run it through a full size DI vessel for final polish, and the resin should last a long time.
keithjmason (12-07-2018)
Old 12-07-2018, 10:58 PM   #12
keithjmason
Thanks. That’s a little bit more reassuring now.
Do you know if higher water pressure would give me a lower TDS ?
keithjmason is offline   Reply With Quote
Old 12-07-2018, 11:16 PM   #13
fatdazza
Generally no, pressure will have more impact on recovery rates.
Old 12-07-2018, 11:31 PM   #14
keithjmason
That’s good, so not worth me going after a pump then. Thanks for your help Dazza!
I guess I should just look at a better DI stage then, I was kind of hoping to stay away from these larger DI vessels, as the resin is quite expensive, and I’ve never found somewhere local to purchase it from.
Anyone know anywhere near Farnborough, Hampshire to get hold of resin ?
Keith.
Old 12-07-2018, 11:51 PM   #15
fatdazza
Out of interest what are your recovery rates and what do you do with the reject water?
Old 13-07-2018, 12:45 AM   #16
keithjmason
At the moment it seems to be something like for every 1 litre of water in, I get 250ml of RO water, and 750ml of ‘waste’
RO water passes though the DI and goes to a small tank for later use. And the waste goes to a water butt for general stuff like washing and watering garden. Hopefully this water is not too bad for the plants.
The Following User Says Thank You to keithjmason For This Useful Post:
fatdazza (13-07-2018)
