Old 16-09-2018, 04:13 AM   #211
wrxmania
wrxmania's Avatar
Brilliant work.
The Following User Says Thank You to wrxmania For This Useful Post:
jas_racing (16-09-2018)
Old 16-09-2018, 07:21 PM   #212
Sicskate
Sicskate's Avatar
Excellent work mate
Sent from my FRD-L09 using Tapatalk
The Following User Says Thank You to Sicskate For This Useful Post:
jas_racing (17-09-2018)
Old 17-09-2018, 09:15 AM   #213
Tuddie
Tuddie's Avatar
Send a message via MSN to Tuddie
Wish there were more folk restoring these amazing cars. Great work buddy
Tuddie is offline   Reply With Quote
The Following User Says Thank You to Tuddie For This Useful Post:
Old 17-09-2018, 09:28 AM   #214
Excellent update
Coming on really well
Old 03-10-2018, 08:59 PM   #215
jammytask
I'm following this excellent thread closely, I'm currently restoring the engine bay of my '98 20V n/a. What state were your front Eiffel Towers in before you started out? Chris
jammytask is offline   Reply With Quote
Old 03-10-2018, 10:13 PM   #216
DC240S
Nice work on the trim! Projects really looking good.
Can I ask what paint manufacture your using? Is that by aerosol?
DC
DC240S is offline   Reply With Quote
The Following User Says Thank You to DC240S For This Useful Post:
jas_racing (11-10-2018)
Old 11-10-2018, 10:42 PM   #217
jas_racing
jas_racing's Avatar
Fronts were wrecked and had to be replaced, rears weren't too bad and could be rescued with a bit of rust treatment and POR
jas_racing is offline   Reply With Quote
The Following User Says Thank You to jas_racing For This Useful Post:
jammytask (16-10-2018)
Old 11-10-2018, 10:44 PM   #218
jas_racing
jas_racing's Avatar
DC
Thanks!
All by aerosol, silver stuff is Hammerite, satin and gloss black are Simoniz, primers are either Hycote or Wurth
Old 11-10-2018, 11:08 PM   #219
jas_racing
jas_racing's Avatar
Time for another update
Some small details first...the wiper arms front and rear needed a spruce up with zinc primer and satin black...as they were:
Rubbed down:
Primed:
Two coats of satin black:
Fitted, with new aero wiper blades:
Sideskirts fitted (didn't take enough photos of this stage as I was in a foul mood that day as I recall ) with a combination of Tiger Seal as an adhesive and bracket/clips on the underside. Driver's side:
Passenger side:
Stainless fixings on the ends:
The Following 3 Users Say Thank You to jas_racing For This Useful Post:
neilb62 (11-10-2018), Sicskate (11-10-2018), Tuddie (15-10-2018)
Old 11-10-2018, 11:53 PM   #220
jas_racing
jas_racing's Avatar
Sill trims next...just needed a clean up and refit...before:
Cleaned up and covered with lashings of Aerospace 303:
Driver's side before and after:
Passenger side before and after:
I tidied up the wiring and connections for the (new) horns:
Screenwash tank refitted:
New pump:
Under bonnet wiring loom for the headlights after cleaning and re-wrapping with loom tape:
Re-fitted:
Onto one of the last big jobs on the exterior, the headlights. The 'clear' covers fade and degrade and look pretty poor so the best option is to re-polish them. This involves sanding away the outer 'protective' plastic coating then refining and machine polishing, but first the clear covers needs to be separated from the base.
Before:
Some people use a heat gun to soften the adhesive that holds the clear cover onto the base but I opted for the oven technique - 80 degrees for 30 mins then get cutting and gouging around the perimeter with a small flat-blade screwdriver. After about 20 mins and about half way around I stuck it back in the oven for a further 15 mins then carried on with the screwdriver to arrive at this:
Both units stripped:
One of the 'clear' covers offered up to daylight:
I got stuck in first with 240 grit paper to remove the rubbery protective film, them refined with 400, 600, 800, 1000, 1200, 1500 and 2000 grit paper. After this stage:
Then onto machine polishing with my trusty DA...awkward due to the shape and time consuming to get a good result but worth it in the end:
Side-by-side:
Both done:
The bases and innards were cleaned up and treated with Aerospace 303 too, then re-assembly could begin:
Trusty Tiger Seal to adhere the clear cover back onto the base, with masking tape holding them together while it cured:
Both done:
I decided a while ago to upgrade to LED bulbs; the original lights are terrible (you might as well hold a candle out the window), upgrading to Osram Nightbreaker bulbs helps but not much, and HID's are good but not really legal, so LED's courtesy of a Fiat Coupé Club group buy seemed a good plan. The kit:
Comparison of the standard bulb vs LED:
Dip and main beam fitted:
Re-fitted to the bonnet:
View from above:
Very happy with the results on the headlights, time will tell how well the LED bulbs work
The Following 9 Users Say Thank You to jas_racing For This Useful Post:
carrera2.05 (17-10-2018), jammytask (16-10-2018), neilb62 (12-10-2018), percymon (12-10-2018), Sicskate (11-10-2018), slim_boy_fat (12-10-2018), Starbuck88 (12-10-2018), Tuddie (15-10-2018), Wrigit (12-10-2018)
