Closed Thread
Old 01-12-2007, 02:28 PM   #1
Phil H
Phil H's Avatar
DoDo Lime Prime scratching the surface!?
I am currently sorting my bike over winter months and am in the process of polishing the plastic fairing.
I am using my rotary with a blue spot pad and 85RD as always. I decided to try some lime prime instead of the usual hd cleanse but for some reason the LP is swirling it up again!? not seen this before.
This is the black fairing after polishing:
Application of Lime Prime with a new ***** MF pad (never had trouble with these pads)
After removing the LP
brinkman:
Camera flash:
After re polishing with 85RD (looks spot on again)
Application of HD cleanse on the other side of the same mf pad (just to test the pad)
HD removed:
Brinkman:
Camers flash:
you can obviously see the difference left by both pre wax cleaners. I havnt seen this before?
any suggestions?
Phil H is offline
Old 01-12-2007, 02:34 PM   #2
spitfire
spitfire's Avatar
Try the lime prime again on the same part to see what happens
spitfire is offline
Old 01-12-2007, 02:53 PM   #3
RisingPower
Pad you're applying the lp is buggered on that side maybe or maybe a different microfibre you're using to take it off is knackered?
RisingPower is offline
Old 01-12-2007, 02:57 PM   #4
Mike_001
Mike_001's Avatar
I did a black Lexus with ridiculously soft paint this week.
Also used Lime Prime but had no problems at all.
Mike_001 is offline
Old 01-12-2007, 03:30 PM   #5
Refined Reflections
Refined Reflections's Avatar
Location: Norwich, Norfolk, East Anglia, England, United Kingdom, 3rd Rock from the Sun
Only thing I can think of is Lime Prime does contain some very mild abrasives, and as such these need to be broken down, by hand its easy but it does need a little effort to do. Just a thought, as I've used LP on black honda paint and no issues.
Refined Reflections is offline
Old 01-12-2007, 03:37 PM   #6
GlynRS2
GlynRS2's Avatar
Lime Prime doesn't feel abrasive - I would try another applicator pad?
GlynRS2 is offline
Old 01-12-2007, 03:50 PM   #7
rockape
rockape's Avatar
lp was used at the cornish meet on both porches dark blue. with no problems.
does seem a bit odd
rockape is offline
Old 01-12-2007, 03:51 PM   #8
PJS
Master of Disambiguation
PJS's Avatar
Send a message via AIM to PJS
LP shouldn't have any abrasives in it at all - it's just a chemical cleaner to remove oil residues from whichever polishing compounds you used for correction that contain them - chiefly your Meguiar's (and 3M?). Shouldn't need to use it after Menzerna - but it'll do no harm if you do.
I'd have to say it's either an application pad/removal cloth issue, unless you've got a dodgy bottle of LP for some reason or other.
As already suggested, try using a different applicator/remover and on a different panel to see if you're still getting the same result.
PJS is offline
Old 01-12-2007, 03:55 PM   #9
Aaran
lp does have very very light abrasiaves, even the dodo said it did
i wonder, it looks on the application pic you went side to side, how come you have circular swirls?
perhaps it was already swirled up and the lime prime removed all the fillers from another product? just a thought
Aaran is offline
Old 01-12-2007, 03:56 PM   #10
rubbishboy
rubbishboy's Avatar
How about doing an IPA wipe down after the 85RD and checking. The oils in it could be masking the swirls and the lime prime is then removing those oils where as the hd cleanse doesn't or leaves behind it's own that are masking them. Those swirls look circlular, but the lime prime looks to have been applied in straight lines. If it is the product the scratches will be in what ever direction the product was applied.
rubbishboy is offline
Closed Thread
